Ball valves
Re: Ball valves
Ball valves make a poor throttle because they open too much too quickly. They are really intended for "shut-off" applications. There are some ball valves made that do not have a round hole in them; it is more of a teardrop to try to reduce the too open too fast issue. I studied all this for a work project.
Re: Ball valves
Aren't gate valves also intended for on-off applications?
Dan Watson
Chattanooga, TN
Chattanooga, TN
- Trainman4602
Re: Ball valves
How about a fast-opening globe valve (i.e. "Whistle valve"). Globe valves are designed for throttling/restricting flow. Everything I've read says that gate valves are not intended for this.
Dan Watson
Chattanooga, TN
Chattanooga, TN
- Trainman4602
Re: Ball valves
Dan I have been using them for 40 years with great success. The K4 Has one and I have never had trouble with it.
In fact Cagney locomotives have them for throttles.
Re: Ball valves
Gate valves aren't intended for throttling, just like ball valves. The flow characteristic curves are nearly identical. Meaning the % total flow to % total opening graphs are alike. Whereas a globe valve is much closer to linear than the curve ball/gate valves have. Not to say they won't work, there's too many locomotives out there with ball valves to say that. They're just not the ideal choice.Fender wrote:How about a fast-opening globe valve (i.e. "Whistle valve"). Globe valves are designed for throttling/restricting flow. Everything I've read says that gate valves are not intended for this.
I'm going with the globe on my shay. Took a commercial solid bronze glove valve and machined the threads off the stem.
The locomotives in the Stillman-McCormick park in Arizona used this set up for their throttle too, and those are 5" scale 15" gauge.
And another thought, look at a prototype throttle valve. It's essentially a globe valve, and the early T boiler shays actually used globe valves as throttles.
-Tristan
Projects
Projects
Re: Ball valves
My feeling about ball valves is that most of the ones in use are too big thus they open too fast. I had a 3/8" on my 3" bore engine and the opening curve was perfect. I have a 3/8" on the Hunslet 2 1/4" bore and it opens a bit quickly. A 1/4" ball valve would have been perfect and would pass the total flow needed. As it is with the 3/8" the engine will go WAY WAY too fast.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Re: Ball valves
It isn't just ball valves. The 4-4-0 that i reworked a couple of years ago had a sliding type valve on it with a round hole. The whole thing looked too big for an Allen loco throttle to me, but I put it back into the new boiler since that is what the locomotive came with. It would open up really quickly too, causing the locomotive to break loose and slip wildly if you didn't open it slowly. It would have been a lot better with a smaller hole in it, I think.
I've found that ball valves are quite controllable when properly sized. Maybe it's just that I've gotten used to them.
Re: Ball valves
My 2 1/2" Shay 2 x 2 has a 3/8" stainless ball valve that has worked perfect for the last 5 years.
John B.
John B.
- Trainman4602
Re: Ball valves
Yes ball valve that are of quality will work but I don't like the 90 degree open to close.
Re: Ball valves
My throttle linkage adjusts for that. The throttle has more like 45 deg. throw.quoteYes ball valve that are of quality will work but I don't like the 90 degree open to close
John B.
