I have some tender frames, cab sides and fenders I want cut out for my latest Gauge 1 project. Nothing that requires extremely close tolerance. The material is 1/16" and 1/32" brass. What are your suggestions/experiences on laser vs water jet.
Many thanks in advance, Bob Sorenson
Laser vs Water Jet
Laser vs Water Jet
Bob Sorenson, Harrisburg, South Dakota
Re: Laser vs Water Jet
Waterjet is more expensive and is able to cut thicker material than Laser but in gauge one that is probably not a problem. The finish on the cut edge is better with water jet but for me the cost effective solution is laser cutting
www.northernsteam.com
Bob,
Shops that do Laser cutting generally don't like materials like Brass or Aluminum because of their reflective nature which prevents having a nice clean edge.
Get price quotes for both processes. If the Water-jet isn't much more expensive, or you just don't want to spend time filing off the rough edge, I'd reccomend going that direction.
Also, when shopping around for a shop that does water-Jet cutting, ask if their cutter has a gyroscopic head. It's a relatively new technology that pivots the cutting nozzel to compensate for the connical kerf normally seen when laser or water-jet cutting. At 1/16" and 1/32" it doens't mean a whole lot, but the thicker the material the more important it becomes.
Cheers,
Curtis F.
Cheers,
Curtis F.
25+ Years of SolidWorks experience...now I feel old.
"You can lead a horse to water, but you can't make him drink."
"Winning an argument on the internet is like winning the Special Olympics."
www.facebook.com/HillcrestShops
