Where to buy steel track or steel rail?
Hello...
I am considering building an old steam powered sawmill for fun. Its based on the old Frick designs and these had what look like small train rail mounted on the husk base to move the log carriage back and forth.
Where do you train guys buy your steel rail? What are the sizes of rail you normally work with? I will need a bout 80 to 100 feet of steel rail in all.
D.Emch
D.Emch
Re: Where to buy steel track or steel rail?
probably 12 to 20 pound per yard rail would do the job. these are used for 15" and 2ft. ga. railroads. don't know where to get it.
fred v
fred v
emchd wrote:Hello...
D.Emch
Re: rail
Right now I am thinking smaller gage. Somthing like that used for old antque mine carts or the smaller scale rails. If the rail has a height of about 1.5 to 2 inches or so, that should work just fine. But it should be durable because of the back and forth wear this will get.tomc wrote:What scale r u talking about? Full size or smaller, that will make a difference on what size rail to suggest and where to get it.
Re: rail
Check your yellow pages for used equipment dealers. If there has been any mining in your area, it's possible they could have used rail and mine cars, although my thinking may be somewhat outdated now that 30 years have passed since I saw such things in Utah.emchd wrote:Somthing like that used for old antque mine carts or the smaller scale rails. If the rail has a height of about 1.5 to 2 inches or so, that should work just fine.
20 Pound Rail
If 20 pound rail is adequate for your needs check with kirklandhobbies@knology.net. The are advertising 1200 feet of 20 pound rail plus a switch or two for sale. Bill
rail
I still am not sure of what size u want. 12# is available from steel dealers. Tom Miller has steel rail available. Go to
www.discoverlivesteam.com and place a want add.
tom_at_srclry_com
A student of the Southend RGS!
you only need rail for 1 side the other rides on an inverter angle iron with a V wheel to insure location. Check the sawmill at my site. We use full size rail I believe on the 1 side.
www.hesstonvolunteers.com
Websites under changes but it may help. I can take a bunch of pictures next weekend if you want.
mikell
mikell
HOLLY COW!!! What a website! What a place! This is s toy store for big boys. To bad you guys scraped two of those three steam cranes as I could certainly use one these days.Anonymous wrote:you only need rail for 1 side the other rides on an inverter angle iron with a V wheel to insure location. Check the sawmill at my site. We use full size rail I believe on the 1 side.
mikell
I didnt find any detailed photos on your saw mill however. The text states that its a curtis, and curtis was one of the makers of circ saw mills. I think I may have laid my fingers onto some curtis documentation so isnt that ironic.
It must be a total barrel of monkeys getting these vintage steamers running....
Curtis Photos
I would very much apreciate any further photos on your curtis sawmill. Would it be possible to also post three descriptive photos of your sawmill on the Old Woodworking Machine Site at www.owwm.com under the curtis machinery heading? Currently we have no examples in the wild of this machine your example is fantastic. We also would love to awknowledge the source of the photos as well as your local for turist purposes if that is O.K.
Thanks. A nice overall shot showing the beastie. Nice to get the curtis name. Then a good shot of the carriage, the headblocks and the set works. And one of the blade drive system. Once again, thanks.mikell wrote:I'll get some pictures this weekend. Any part in particular you would like to see.
mikell
