K4s Photos
- JBodenmann
K4s Photos
Hans asked for some photos of the K4s so here you go. I like the original chicken coop pilots that the engines were built with. Like the originals this one was all steel.
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
Here are the little window frames for the cab windows. They are made of beech. Beech is a very nice wood for model building, especially if you are modeling oak. Beech is a member of the oak family and has the appearance of miniature oak with the correct little rays and dots. But it has a very fine closed grain and takes a finish quite nicely. These little frames are made on a router table with some commercially available tiny little dadoe cutters. You will have to make a mandrel to hold them and a spacer to go between them to cut the little tenons. The tricky part is to make a fixture to hold the little pieces. Keep them fingers safe! The frames are made to accept 1/16" glass. This glass is available at stained glass shops. They mostly use it to press flowers between. Too Much Fun!
- JBodenmann
Here is the Johnson bar. I have wondered how that name came to be. I really enjoy making little pieces like this. A delightful little puzzle! When sizing up a model locomotive one of the first places I look is in the cab. To me a locomotive that has a well modeled cab is much more fun to operate. It helps to create the illusion that it is a "real" locomotive and that the operator is an oversize gomer. More of a connection with the days of steam.
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
