Quartering driver axles
I have a diferent way of cutting the keyways 90 deg to each other than the usual sqaure block or dividing head routine.
I turned up my axles to the regular allan prints then,
i drilled and countersunk the ends to fit a 10-32 flat head screw. so that you can seal it up after greasing. and the head is flush with the end. then at the intersection where the threads meet the countersink i recut a set of 60 deg centers so that you can still turn everything between centers and be true.
then i made a triangular piece with a perfect 90 between the 2 sides. drilled a clearance hole for the #10 screw up in the corner.
then bolted it onto the end. set in vise, indicated one leg true. then cut the keyway. loosen vice , index so the other flat is true , then cut the keyway on the oposite end. done! quick , easy, and not a waste of alot of material , or having to lift any heavy or cumbersome atachments.
i keep forgetting that the pics show up in the oposite order that you place them!
- Trainman4602
I have an awful feeling I am probably showing myself up here but, and no I have not got round to quartering my wheels yet but. 45deg method do you mean both side of the nominal centre line and what advantage is that over 90deg away from each other.
I have never understood why cutting four key ways, each pair at 90 to each other seems so difficult. Isn’t that what rotary tables are for? There seems to be more folk lore and ideas out there on this subject than most others.
Is it just a case of most model engineer’s work without loads of gear and the folk remedies out there are get rounds?
What is puzzling me at the moment is generally one side will have the key way aligned with the centre of the balance weight. What’s the clever way to get the first keyway aligned correctly and how do you replicate it. I am thinking get the two bores lined up then give it a spin on the rotary table the required amount?
Another surprising thing I just noticed looking at the drawings again is you would have thought the offset for the balance weights would be the same on all wheels, well I would. Checking my drawings I see they vary, leading and trailing are 5deg intermediate is 7deg and driving is 9deg. For one horrible minute I thought I had got my drawings wrong but checking the originals and I am OK.
jim
jim
- Trainman4602
Re: Quartering driver axles
Just to follow-up, Dave's 45 degree method video is linked from here:
http://ibls.org/mediawiki/index.php?title=Quartering
Regards,
Daris
Regards,
Daris
Hello gcarson,
what about using those clamping parts? Please see:
viewtopic.php?f=45&t=103319
Best regards
Asteamhead
Best regards
Asteamhead
FWIW,
With the 45 degree method, you only need one broach fixture. Make all wheels with the same fixture - no need to reset anything. You do have to make sure the key slot is as close to 45 degrees from the crank pin as possible. All of the axles get a slot in line with each other. When assembled, the 90 degree pin set up is automatically generated. A few shots from my old web page
- Attachments
Bruce Mowbray
Springville & Southern RR
TMB Manufacturing & Locomotive Works
I quartered the axles on the mill using a woodruff cutter and end mill during a single setup.
i know some do not like this method, but it was the only way i can be sure of the quartering using the tools in my "tool box"
if it works...what is there not to like?
- Trainman4602
The problem with the method is that you have to reset the cutter for each axle not only slow but more chance to screw up.
