snifter valves
Re: snifter valves
I would put drifters on the RRSC mikado or you could pull crud into the cylinders and valves when drifting. People will say oh you can leave the throttle slightly cracked, but that won't always happen and when you forget or someone else is running it, you'll pull grit into the cyls/valves.
Re: snifter valves
Perhaps they know something that the remainder of the world has not discovered?
Re: snifter valves
Piston valves suck?Bill Shields wrote: ↑Tue Aug 14, 2018 10:58 am Perhaps they know something that the remainder of the world has not discovered?
