New Year.....New project
- JBodenmann
Now even though I promised myself that I wasn't going to start any new projects, it seems that I just can't help myself. I have been threatening to build a 3/4" scale engine for some time. So January first seems like a good time to start. The other day a package came from my friend John at Friend's Models-Yankee Shops, and this was inside. Aren't they beautiful. This will be my personal project, just for fun.
- JBodenmann
- JBodenmann
Here is our long skinny piece of iron in the mill being faced with a carbide insert end mill. This works really good with iron. Instead of cutting up a bunch of little squares and trying to machine them individually we will do all the machining we can before we cut it into little bits. So we will make a nice long rectangular piece.
- JBodenmann
Now we will machine the slot where the axle box will fit around the frame pedestal and slide up and down. Here we are using a 1/4" solid carbide cutter. It is important to tram your mill vise before doing this so the slot is parallel with the sides of the axle box. I made the slot .010" wider than the frame pedestal will be.
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
- JBodenmann
And here is as far as I got today before I ran out of gas. Six cute little axle boxes and cellars ready for drilling and boring. I really enjoy building in this scale. Materials cost is nothing, compared to the amount of enjoyment. By now you are probably wondering, what the heck is he building? I think I am building an 0-6-0. Originally designed by Mr. HJ Coventry. His drawings are beautiful! But being as that I could never color between the lines I am making a couple changes. The main change is that will be building the engine as a saddle tanker. Sort of a poor man's B & A Tanker. No tender between me and the cab when running. At least that is the plan so far. I would like to hear from other 3/4" scale builders out there.
Happy Model Building
Jack
Jack
Jack,
I had almost thought of doing the Kozo A3 tender axle boxes that way, but I eventually decided to just follow the book as it was easier for me as a beginner. The thing with Kozo is, he often does things the long way, assuming very rudimentary tooling, but if you follow the book in absence of other information, you can't go wrong, according to several people who have completed the engine.
Attached is a PDF drawing set I did for the concept. Page 2 shows the bar. The premise was a slitting saw of a specific width to perform the separation, but I don't actually know if that works as a final machining operation, or if you'd want more meat on each piece and then face them down in an additional operation after you part them off the bar. I've yet to use a slitting saw in my mill. Would my planned method have worked?
I bought my A3 driver castings from John and they are much nicer than any other casting I have run across so far in this hobby.
I'm glad you're starting in on a small scales project after all that really big stuff. Don't know too many other people in Cali working on 3/4" scale...you, me, Pat Hutcheson...and is Andy Romer working on any new engines?
- Attachments
- tender-journal-decimal_v02.PDF
- (153.37 KiB) Downloaded 197 times
Re: New Year.....New project
Yes!!! No apologies from me for being enthusiastic, but is nice to see an experienced builder working in the perfect scale.
JohnS.
JohnS.
JBodenmann wrote:Now even though I promised myself that I wasn't going to start any new projects, it seems that I just can't help myself. I have been threatening to build a 3/4" scale engine for some time. So January first seems like a good time to start. The other day a package came from my friend John at Friend's Models-Yankee Shops, and this was inside. Aren't they beautiful. This will be my personal project, just for fun.
