cylinder cock design from latest live steam mag...
Cyl Cocks
Busy right now with a dealer in CZ, and power / internet flaky from storm.
Will get a drawing together and post it shortly (may be a day or 2)
Re: Ball and ramp drawings
Bill,
I would like to see the Ball and Ramp drawings when you look them up as well.
Rob Guthrie
Rob Guthrie
- tsph6500
Re: Steam Cocks
I would be interested too.Bill Shields wrote:Need drawings?
Thanks.
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer & Fireman
Jim Leggett
Al,
They use a mechanical linkage, like so many other cock-type drains. If you think about it a plug cock with small passages wouldn't have to be rotated 90� to close. Given a plug of say 1/4" diameter with 1/16" passages, the minimum rotation needed to completely close the cock would be 30�.
GWRdriver
Nashville TN
Nashville TN
BALL - RAMP - SPRING - DRAIN - COCKS
Here is a very rough drawing of what I have used many times. It is not only a drain, but a relief valve in case the cylinder fills up with water.
Excuse the crappy spring drawing, but you get the idea.
A = valve ball
B = ramp ball
C = spring
D = Pin to hold it all together. I just slid in a brass escutcheon pin and bent the end over slightly so it wouldn't fall out. Not very high tech, but functional.
The main body can be as small as 1/4" diameter.
The 'rod' with the ramp is 1/8" thick x .093 high in this example, but that is not a critical size either.
The only fiddly thing is the spring. I used a bronze spring from a ball point pen in my Hudson (30 years ago), and they are still there. I adjusted the 'ramp' angle and height to make the spring I had work.
I have, on occasion made them for people without the bottom ball and just had the spring ride up / down on the 'ramp'. It seems to work OK that way also.
You can activate the rod either from one end or from the center, depending on your circumstances.
I see that I forgot to label the 'discharge hole' seen on the right hand sketch, just above the ramp ball. This blows the steam / water out to the side, rather than digging up the ballast and making a mess of things.
Be creative, this idea isn't new - I have seen dozens of variants, all of which worked just fine.
Back to work now...
A = valve ball
B = ramp ball
C = spring
Back to work now...
Drains
If you want steam operated drains for a bigger loco, I have good drawings for them also.
- Greg_Lewis
Manual cylinder cocks
FWIW: Locoparts offers manual cylinder cocks in 2-1/2" scale.
- gwerhart0800
Re: Manual cylinder cocks
I looked at the locoparts.biz website and I don't see them.locoparts wrote:FWIW: Locoparts offers manual cylinder cocks in 2-1/2" scale.
George Erhart
Loveland, CO
https://lovelandcreatorspace.com
Loveland, CO
