cylinder cock design from latest live steam mag...
gwrdriver
Post by gwrdriver » Sat Mar 14, 2009 7:24 am
For the same reason I know not to, probably.
GWRdriver
Nashville TN
tsph6500
Post by tsph6500 » Sat Mar 14, 2009 8:06 am
gwrdriver wrote:At that time Bon-Ami was made of diatomeceous earth and was just the thing for seating model parts. I don't know what it's made of now, but I've no doubt it has been "improved" to the point where it's useless.
There are diatomeceous earth products for insect control at our gardening centres and big box stores. I believe they are nearly 100% "earth" with an attractant added.
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer
gwrdriver
Post by gwrdriver » Sat Mar 14, 2009 8:50 am
Jim,
That's interesting to know and worth investigating. If anyone is like me even the smallest can of a very fine grit of Clover Compound would have lasted several lifetimes so I never bought the right stuff. I kind of wish I had now, or figured out a way to share a can, instead I tried everything else like toothpastes, Bon-Ami, other souring powders, etc. and just made do. I also have never tried Timesavers which I hear is good.
GWRdriver
Nashville TN
OPen Cocks
Post by Bill Shields » Sat Mar 14, 2009 9:25 am
Open Cocks are also useful if the throttle is leaking a bit and you don't want water accumulating in the cylinders while standing.
gnsteam
Post by gnsteam » Sat Mar 14, 2009 12:59 pm
On the topic of cylinder drains. Can anyone identify this style of steam operated cylinder drain that came with my 1" scale GN Mikado? They appear to have been mass produced due to the process required to make the diaphram (white plastic disc with to projects to seal the drains outlet). Are they still available? I need replacement diaphrams for two of the valves.
Fred
Fred
Bill Wilkins
Cyl Cocks
Post by Bill Wilkins » Sat Mar 14, 2009 4:30 pm
Those look just like mine which were from Railroad Supply. My discs looked like yours, deformed from the steam pressure. I made new discs from .030. Some said you could take out the brass disc with the thicker disc, I left mine in. I'll know how the work in a bout two months.
Bill W.
gnsteam
Post by gnsteam » Sat Mar 14, 2009 11:58 pm
Thanks Bill,
Having seen these drains and taking them apart for the first time. I assumed the deformed projections where made that way from the begaining. Didn't cross my mind that they became that way under constant pressure. Two of the discs are cracked through the projections. So all I need to do is make new flat discs.
Thanks for the reply!
Fred
Fred
gcarsen
Post by gcarsen » Wed Mar 25, 2009 1:56 am
I was watching this posting, and today a project came in the door. figured i would share with you folks! a full set of fullsize cylinder cocks came in to have new upper bodies made. here are photos of the fullsize one and dissasembled so you can see how they where built. came off a smaller loco. 2-6-2 wheel arrangement. it is operated by flat bar in the lower slots with ramped area to lift the valve of of the sealing surface.
Harlock
Post by Harlock » Wed Mar 25, 2009 2:04 am
Bill, that is some delicate plumbing protruding from the bottom of the cylinders! :) May all your tracks be tamped and your gauge be true...do you have some sort of strike plate below that level that will hit the track first?
As a followup to this discussion, we came up with our own design for a mechanical cock and it is working very well on air at least. We'll post some pictures and plans when they are finished. It's been great to see the 'dozen ways to skin a cat' postings, and we've just added another one I think...
Contributing Editor, Live Steam Magazine
Webmaster, Allen Models of Nevada
pockets
Post by pockets » Wed Mar 25, 2009 6:58 am
gcarson,
Thanks a ton. Between your photos and BS's drawings, even I can develope a train of thought on the ramp type valves.
Greg B.
When the man at the door said, "Alcohol, Tobacco and Firearms," I naturally assumed it was a delivery.....
"From my cold, dead hand!" C. Heston
Kimball McGinley
Post by Kimball McGinley » Wed Mar 25, 2009 2:24 pm
Harlock: I have to agree! That piping looks scary delicate and vulnerable! On my 0-4-0, I figure the front step type pilot "L"-shaped will make a good skidplate.
gcarsen: Where did you get that little quarter? Ha-Ha! What has worn out that new bodies are needed?
Lever operated from cab - Coles plug type valve
gcarsen
Post by gcarsen » Wed Mar 25, 2009 2:31 pm
we need to replace the upper body because the root of the threads that go into the cylinders have cracks in them. odball thread too! some thing like a 6tpi tapered pipe thread that i will need to match. the thread that the body threads into is a standard. at assembly we can run a tap into that thread to get the timing right for the valve bar.
