3/4" pumps Van brocklin
SteveM
Re: 3/4' VanBrocklin pumps
Post by SteveM »
steamingdon wrote: Sun Apr 12, 2009 7:18 pm Here is a shot of my shop.I`m not a neat freek in the shop so close your eyes if this bothers you.
I WISH my shop was that neat.
Currently in the process of moving just about EVERYTHING in the shop to rationalize the storage and the machine layout.
JohnR
Re: 3/4" pumps Van brocklin
Post by JohnR »
Thank you
JohnR
Post by JohnR »
Thank you for the response Bill on the prints. What alloy bronze do you recommend
for the steam cylinders and the pump body.
Thank you.
Post by Bill Shields »
i use brass of whatever i have laying around for 90% of it. Since there is no metal to metal contact, it really is not a concern.
what the brits call gunmetal is good for the steam end..or any bronze you can lay your hands on.
the pump i am currently using is all just straight brass...
steamingdon
Post by steamingdon »
bronze will cost a good penny these days. No need as Bill S. already stated. :D
steamer
Builder01
Post by Builder01 »
Here's a video of the 3/4" pump I made from Bill's drawings. Steam and water cylinders are made from brass. The pistons and slide valves are made from phosphor bronze. Piston rods and valve rods are stainless steel. The pump is putting water into the boiler at 100 psi. All seals and piston rings are Viton. Thanks Bill for making the drawings available, these pumps are so cool!!
steamingdon
Well! talk about turning things around. First time I`ve seen this arrangement, I must say.
steamer
Builder01
Post by Builder01 »
I wanted to be able to watch the valve spindles and actuating arms! You also get to see the valve chest. Why hide the fun stuff??
The only drawback to this 'arrangement' is that it is sometimes difficult to 'adjust' the valve arm actuators since the screws are up against the boiler.
However, once set (which can be done on air before installation)...they very rarely need to be moved.
Looks very nice
alco2350
Post by alco2350 »
That is a beautiful pump! Are the drawings still available?
Britt
Builder01
Post by Builder01 »
Yes, the drawings are available. I believe the link is somewhere in this thread. Perhaps Bill could repost it here.
Yes, if an actuating arm loosens, or, needs adjustment, this arrangement can make it a challenge to get to the set screw. This actually has already happened to me one time. I was able to get my allen wrench behind the pump and re-tighten the screw. Not really a problem. Thanks again Bill!
alco2350
Post by alco2350 »
Builder01 wrote: Mon Sep 16, 2019 11:11 am Yes, the drawings are available. I believe the link is somewhere in this thread. Perhaps Bill could repost it here.
I missed the link but found it when I went back through. Thanks!
Britt
