Many questions
Many questions
[img]/ubb/images/graemlins/confused.gif"%20alt="[/img]
Hi:
I just finished My first stationary engine and now Im to the point of many questions.
First on cylinder lagging. I have some oak veneer that would look nice , but Im going to run the engine alot and dont know if the veneer would hold up to the heat.
Other wise Ill use metal brass sheet ect.
Second Im starting the boiler and have plans from coles for the portable.
How can I tell if copper tubing is seamless, or is it all seamless. Also I went to purchase Sil-Fos for brazing and find Sil-Fos , Sil-Fos6 , Sil-Fos12, ect . What is the proper sil-fos to use on copper boiler work , or is there something better.
Many Thanks In advance.
Ted
Hi:
Ted
Re: Many questions
Hi Ted, your veneer will work fine if you do it right. First glue it down to a sheet of heavy paper, then use a craft knife & straight edge to cut through the veneer but no the paper to create the planks, now trim the thing to the exact size/shape you need & trial fit it until you get it right. Take it back off & give it several coats of a good clear varnish. Attached is one of mine.
What Engine is it
What Engine is it
Tel
Re: Many questions
'Sil-fos' or any of the phos-copper brazing alloys are not a good material to use on copper boilers. It's cheap and it's fluxless but that's all and it represents a potential safety hazard from stress cracking in the joints, especially in the presence of coal smoke. You probably won't fire with coal but in any case a better material choice would be a 45% silver solder which all of the major mfgs make.
GWRdriver
Nashville TN
Nashville TN
- Location: Alsace a Part of France along the Rhine River
Re: Many questions
A good thing against anonymus posters: NO ANSWERE !!!!
Have Fun
dampfwilli
You must not be crazy to play with steam, but it helps.
dampfwilli
Re: Many questions
Awww, c'mon willy, at least he signed it "Ted". [img]/ubb/images/graemlins/grin.gif"%20alt="[/img]
Ron
Ron
Re: Many questions
Tel, I see that you "swizzled" that purty valve fitting on the side of the cylinder to shape it. [img]/ubb/images/graemlins/cool.gif"%20alt="[/img]
Unka (Swizzles some myself) Jesse
Re: Many questions
Ted, RE: The copper tubing. As far as I know (and that ain't very far) all the copper tubing is seamless drawn. Although I haven't any experience with any copper tubing over about 2 " dia. , I bet the bigger stuff is seamless also. [img]/ubb/images/graemlins/cool.gif"%20alt="[/img]
Stay away from the Silfos or whatever and do as was suggested and get some real silver solder, the more silver in it, the better it works.
Don't worry about the wood being damaged from the heat unless you are using a high degree of superheat. Take a look at the homebrew logging locomotive in the attachment for a big example of wood lagging.
Unka (likes to silversolder) Jesse
Re: Many questions
Attachment did not download, so trying again. [img]/ubb/images/graemlins/crazy.gif"%20alt="[/img]
Unka (confused) Jesse
Re: Many questions
Good to see yer've taught yerself to swizzle Unk - pretty easy once you get the hang of it eh??
Tel
Re: Many questions
O.K., Unka and Tel, I'll bite. What is to "swizzle"? The only swizzle I know is the stick yoiu mix a drink with. Don't see anything like that in the pics.
Johnny
Johnny
