Subject matter --------PLEASE READ--------
Re: Subject matter --------PLEASE READ--------
Post by Harold_V » Thu May 12, 2016 1:14 am
neanderman wrote:Hear, hear. Thanks for all you do, Harold.
It is my pleasure, especially when I find I'm helping someone in need. Thanks, Ed.
hobbysteam
Post by hobbysteam » Sun Feb 04, 2018 1:40 pm
Guidance requested here! I am new to the forum and I just posted the "Scaling Drivers" question, under a new topic! Tell me, did I do that right or should I have put that somewhere else? If so, can I remove it and post it where it "belongs" at this point? In the future, which is the best way to find the appropriate heading to put it under?
Thanks!
Post by Harold_V » Sun Feb 04, 2018 4:42 pm
Looks fine to me. The subject often overlaps, so placing your post(s) can be acceptable in more than one forum. Do note that we do not allow multiple identical posts, however, so choose one and go with it.
Depends. If no one has responded to a post, and time to edit hasn't elapsed, yeah, you may be able to do that, but the best policy is to ask help from a moderator if you need a post changed. We discourage deleting posts, as that tends to destroy a thread, although not always. It is for that reason editing time is limited, as we've had issues with one reader deleting posts, often long after they were posted.
Sort of a judgment call. As I said, there often is overlap, so pick the forum you feel provides the required exposure. Some readers don't check the entire board, while others read every post. If your question relates to operation of a lathe, for example, but your interest is in steam, you may ask a question in the Lathe forum, where those with interest in lathe work might see it when they may not see it in the Live Steam fora. As I said, a judgment call. You won't get chastised* for choosing the "wrong" one, although if it is better suited in a different forum, it might get moved by administration or a moderator. We don't lose a lot of sleep over such matters on this board.
*Note that we discourage bad behavior on this board. Readers are not free to take shots at other readers. We try to keep things polite.
hobbysteam
Post by hobbysteam » Sun Feb 04, 2018 7:11 pm
Thanks for the explanations Harold, I will take note of the points you make and I will just leave my post where it is and search well before I post again. As to the dialogue "behavior" I do my best, on any of the sites, to just bite my tongue even though it isn't always easy! :-)
Post by Harold_V » Mon Feb 05, 2018 4:19 am
Man, you said it. There's times (even on this board) when I'd like to unload on a guy who has way too much to say, but I, like you, bite my tongue. I have to lead by example, which I try hard to do. Doesn't mean I don't have opinions and want to strike out at others---but I know better. Some of them could really use a good thrashing, too! :lol:
