1 1/2" Mikado on ebay
Does anyone have info on this Mikado on ebay?
Ebay number 200403526763
Thanks
Phil Shaw
Manitoba Live Steamers
Thanks
Phil Shaw
I built a the same locomotive. Its offered from railroad warehouse, www.livesteam.com Its a model of a 90 Ton Light mikado used in the logging industry. It has a 2.25 bore and a 3.5" stroke. 6" drivers, 8-5/8" boiler. It weighs around 500lbs.
Actually, Bob Pedersen did not design the 90 ton Mikado he sells kits for. That started
out as a group build project by the Sacremento Live Steamers. Bob has taken over
supplying the castings as well as waterject cut frames and laser cuts parts. Over the
years he has made quite a few improvements and added lost wax castings, etc. Some
of the original castings are not available and precious few individuals have them.
I am (still) building one, slowly but surely. This is my 90 tonner...
http://iprr.topcities.com/mikado
The USRA Mikado is indeed an old Railroad Supply (Chet Peterson) locomotive.
The rights to the patterns that Bob holds have been hotly disputed, but to be honest I
believe the statute of limitations has been far exceeded for any further claims. Many of
the missing patterns Bob has had to replace with his own because of the squabbles
over ownership.
And yes, the USRA weighs about double that of the 90 tonner.
Bill
over ownership.
Bill
Actually the 90 ton Mikado was designed by Steve Vitkovits and Dick Thomas. They were/are members of GGLS here in the northern part of California. The engine kits were originally sold under the business name of Ferrous-Wheel designs and many were sold/built. Pederson acquired all the patterns/rights to the design and then dug into making a bunch of updates/changes to the overall kit.
I will say this.... Robert Pederson has made many nice changes and updates to this kit!
I will also say this..... Due to his Personality and Consumption of Alcohol one is best not to mention anything related to these earlier designs of this engine as they relate to Mr. Vitkovits or Mr. Thomas. The little man in Nevada will absolutely loose his mind and hang up the phone on you.... And then will never deal with you again.
The engine is nice.... You have been warned....
Robert M.
And Yes. The other engine is the original RailRoad Supply Mikado. An Awesome locomotive!!!!
Robert M.
