Hi Bill,Bill Shields wrote:...........
Download pressure on my firebox is easy to calculate: the firebox is 10" x 11" open to the air. 110 sq inches x 100 psi is 11,000 pounds.
I have 32 vertical stays, 1/2" in diameter
11,000 / 32 = 345# / stay (round numbers here)
area of stay is .2 sq inches (round number) = 1800 # / stay x 6 for safety = 10,000 psi. Plenty of space for corrosion.
So, assuming NO support from the non-vertical stays and nothing from the mud ring, how much would the firebox move as a result of down-load only, assuming A36 Steel?
I am looking for an answer here from someone that wants to join in.
I don't have my books with me (and I don't do it for a living any more), so I am not going to put my 'rememberences' in print to be shot at.
Being a retired naval architect I synpathise with your last remark! However looking at your example of the load on the firebox, isn't it that there is also a load on the boiler shell meaning that the vertical (and horizontal stays for that matter) are carrying twice the load? They are loaded at both ends.
As an example, I can follow your approach, however it seems to describe a sequential catastrophic failure mode, and, if anything, experience in other fields taught me that real life failures act differently than originally imagined.
As for the strength calculations, there are cheap and very functional student versions of finite element methods (FEM) available. Isn't anybody tempted to try one of these?
Kind regards
Jos Koopmans
