Disney American
JBodenmann
Disney American
Post by JBodenmann » Sun Apr 04, 2010 10:57 am
Hello My Friends
Now that Tom's Nickel Plate Berkshire is finished up and he has taken it home, it's time to start the next project. This will be a Disney American. This loco was started years ago and some of the bits are already done. My client wants a highly detailed model faithful to the prototype. There will be some changes to the Disney design such as a wood cab and tender frame. I have a few little tricks to help out with wood doors and windows and will be posting them when those parts are being made. The tender will be brass and copper like the little 0-6-0. One interesting thing is that the driver castings, although beautiful are brass!! So some steel tires will be in order. The frame sides were mostly done but I found a few little boo boos. So here we go, a Disney American. Quite a change from a Nickel Plate Berkshire!
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:00 am
The drawings call out for a brass casting for the engine drawbar keeper. This casting was not included in the parts received so one was just made from bar stock. Here it is getting a spin on the rotary table.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:01 am
After a bit of filing and a trip through the sand blaster.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:06 am
No axle box castings either. The drawings call out for brass castings, not an acceptable material for axle boxes. There was a nice chunk of aluminum bronze leaning against the wall. It was band sawed to rough size and then to the milling machine. A new band saw blade had to be used as the aluminum bronze just laughed at the old one. Also brand new end mills and freshly sharpened drills.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:10 am
Here the axle boxes are sized and the cellars have been fitted.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:13 am
Boring the axle box cellar assemblies. They were bored to within .020 or so and then reamed. I like reamers for sizing holes. That way They all come out the same size.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:16 am
Here the cellars are having the pockets for the oil and felt waste machined. Once again when working with aluminum bronze, a brand new end mill is used.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:21 am
Axle boxes, cellars, and spring saddles. #2-56 x 3/4" flat head machine screws will be used to hold the cellars in place. The axles will be case hardened where they contact the bearings.
LivingLegend
Post by LivingLegend » Sun Apr 04, 2010 11:22 am
Post Deleted
Last edited by LivingLegend on Sun Apr 04, 2010 11:36 am, edited 2 times in total.
JBodenmann
Post by JBodenmann » Sun Apr 04, 2010 11:23 am
Last one for now. Here we have a fat rodent checking the drawings. Ha ha, too much fun!
Jack
LivingLegend
Post by LivingLegend » Sun Apr 04, 2010 11:27 am
Jack:
Glad to see you are following the original Disney design using the axle box as it's own bearing and with a cellar...
Other than the cab and tender frame, I take it you will be keeping true to the Disney 173 as drawn by Eddie Sargent?
Also, are the castings original Disney? Or are the castings the ones the Carolwood Historical Society was selling a few years ago off the Disney patterns?
EDITED.... 04/04/2010 @1730 hrs CDT (Added question)
LL
rwmorris
Post by rwmorris » Mon Apr 05, 2010 11:14 am
Simply Awesome Jack!!!! Can't wait for the updates on this one!!
Cheers,
Robert M.
