Disney American
Re: Disney American
JB...."Fiddle and fit, fiddle and fit, just a job for a bozo like me!"...after seeing your workmanship and attention to detail (not to mention superb craftsmanship)...would HARDLY call you a bozo! You do fine work!
Saw the "keeper" for the bushing key on your main rods...never saw a gizmo like that. Interesting!
Your wooden cab...is fantastic in its own right. And excellent piece of cabinetry. Will only highlight the rest of the locomotive when completed. Can only hope boiler heat does not distort the appearance...but then, that would only add artistic patina. Please...continue to share progress reports. And thanx for sharing your ideas and methods. Carl B.
- JBodenmann
Re: Disney American
Hello My Friends
Thank you Karl B for the compliment. Yes, that key keeper on this engine is not very common. These parts were made by Dr. Thees back in the 1960's. He did a beautiful job on them and all I did was clean and polish them. This cab will hold together as it's a bit over built. This cab will have a metal sheathed roof as did the #173. Even though this engine isn't particularly a model of the 173. Here is one change that I like to make when dealing with Stephenson's valve gear. In the top photo here you can see an eccentric strap and blade as it is usually set up on an engine, both full size and model. The blade is bolted to the side of the eccentric strap. I have never liked this set up. There is no way to precisely adjust the length, which almost always must be fiddled with to get a Stephenson engine to run well in both forward and reverse. So the second photo is how I like to do it. The strap is milled off, and the blades have a plate silver soldered to the end. Then they are just bolted together. Nice place for a shim. This is one place on an engine that I will use alloy allen head fasteners. On final assembly I will give the hasteners a shot of Loctite 271. Some stationary engines did it this way. Number Nine was done this way. The valve gear was very carefully made. But one eccentric and blade needed .007" of shims to get things right. Once set, and done up properly this should practically never change.
Jack
Jack
- Comstock-Friend
Re: Disney American
Jack, The blades bolt to the eccentric strap like your technique on the V&T's 'Dayton', a CP173 sibling so you are not out of line.
(You can see a shim!)
John
John
- JBodenmann
Re: Disney American
Hello My Friends
Just wanted to say hi and let you know why I haven't posted anything for a while. I have been in the process of moving, I hate moving! My goodness you never know how much stuff you have until you move. Many trips back and forth to the new place, a 3-1/2 hour drive. Also many trips to the good will store. I have a machinery mover coming for the big heavy items. I hope to be back to work sometime in October.
See you in the funny pages..
Jack
Jack
Re: Disney American
I sympathize with your challenge. I had to rent three Penske trucks and a crane when I moved my shop.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Re: Disney American
Jack, hope all goes well with,the rest of your move. The thought of moving my shop, which dose not even have any really larg machined is overwhelming to me.
Rob
Rob
Re: Disney American
Well Jack, you can look at it this way...moving a household is a PITA. Moving a shop with the household is a bigger PITA!
However, there are some positives that can come from this: 1) as you're packing (or unpacking) in your new shop...you can weed out the stuff you've collected you don't want anymore. 2) you get to re-organize the tooling and supplies. Sure helps when you can find things faster when they're organized and labeled. Otherwise, you know how it goes...you remember packing things...but can't remember where you squirreled those things away. In my experience...you always find what you're looking for in the last place. Now, if could start looking for things in the last place first...you'd save yourself a lot of time! LOL.
Good luck on the move. Don't mess up your back. Hope you'll be posting loco and/or other project status soon enough. Cheez! Carl B.
- Greg_Lewis
Re: Disney American
And how about all the stuff you forgot you had? That piece of 3-inch bronze round that was in the box under the lathe. You could have used that instead of the one you just bought. And the special shape toolbit you were looking for six months ago — tore the shop apart and still didn't find it then. And, of course, all the empty cardboard boxes from McMaster that you saved to use for small parts but are now too small for packing stuff in and not worth schlepping across the state.
- JBodenmann
Re: Disney American
Well it's been a while since anything was posted on the little tea kettle so here is what has been happening. These engines had what was called a terne plate metal roof. Terne metal was soft iron sheet that was tinned and could be soldered easily. It was not available in large sheets so it had to be pieced together and folded and soldered at the seams. The roof on the model we have here is being made of .005" full soft copper. The seams are folded together and will have the joints soldered. Then it will be silvered with circuit board silver plating solution to give the appearance of tinned stock. This roof covering has been a bit of a challenge, with lots of fiddling and massaging of the copper sheet.
A delightful little puzzle….
Jack
- JBodenmann
Re: Disney American
Here is a bit of an update on the little tea kettle. The terne metal roof is mostly done now.
No shortage of things to do!
Jack
- JBodenmann
Re: Disney American
See you in the funny pages...
Jack
Re: Disney American
Jack, that's nice antique looking water glass for the Disney loco. I'm restoring a Disney 4-4-0 and am thinking of making one for it. May I ask a couple of questions? First, what type of glass are the shields made of? I've used microscope slides for head light illuminated number boards. Would that work for the water glass shields? Second what is the size of the square top end? I and proportion the rest of the water glass assembly.
Thanks Dave S.
Thanks Dave S.
