Eureka Project
Moderators: cbrew, Harold_V
jessebanning
Re: Eureka Project
Post by jessebanning »
woke up at 4 am this morning. Couldn't go back to sleep so I went to the shop. I started in on the eccentric straps. I had the water jet cut. The eccentrics I machined a while back waiting for the cylinder castings.
www.banninglocomotiveworks.com
www.littleengines.com
jessebanning
Re: Eureka Project
Here is the strap with the eccentric.
Postwarbob
Re: Eureka Project
Post by Postwarbob »
Looking good Jesse !!!!
jessebanning
Re: Eureka Project
Just got back from water jet. Picked up the valve chest, now to machine em.
jessebanning
Re: Eureka Project
I got the mounting holes drilled in the valve chests today. Tomorrow I'll finish up the packing gland then drill and tap the cylinder block. Then, make the valves and tie everything in :D
Dwight Ennis
Re: Eureka Project
Post by Dwight Ennis »
Right on!!! PROGRESS!!! :D
Postwarbob
Re: Eureka Project
I might live long enough to see this project done. Get er done Jesse. Work is looking great.
Bob ..........
jessebanning
Re: Eureka Project
I got the rocker arms done. The blanks were water jet cut then a rotary table operation then a trip to the lathe. I hope to have the valves done tonight.
jessebanning
Re: Eureka Project
Here is the rock shaft/arm assembly. A little clean up then paint. The last picture is the 1:1 Eureka.
jessebanning
Re: Eureka Project
I got the piston rods done and the valves done.
Re: Eureka Project
jessebanning wrote:I got the piston rods done and the valves done.
Milling with a drill chuck? (Third picture down).
Not really recommended.
Comments?
joneg
Re: Eureka Project
Post by joneg »
i agree Harold, milling with a drill chuck is a recipe for disaster. i have seen them pop off the jacobs taper
