Page 12 of 16
Re: Eureka Project
Posted: Tue Aug 14, 2012 8:30 am
by jessebanning
woke up at 4 am this morning. Couldn't go back to sleep so I went to the shop. I started in on the eccentric straps. I had the water jet cut. The eccentrics I machined a while back waiting for the cylinder castings.
Re: Eureka Project
Posted: Tue Aug 14, 2012 10:56 am
by jessebanning
Here is the strap with the eccentric.
Re: Eureka Project
Posted: Tue Aug 14, 2012 4:30 pm
by Postwarbob
Looking good Jesse !!!!
Re: Eureka Project
Posted: Wed Aug 15, 2012 11:27 am
by jessebanning
Just got back from water jet. Picked up the valve chest, now to machine em.
Re: Eureka Project
Posted: Wed Aug 15, 2012 6:48 pm
by jessebanning
I got the mounting holes drilled in the valve chests today. Tomorrow I'll finish up the packing gland then drill and tap the cylinder block. Then, make the valves and tie everything in
Re: Eureka Project
Posted: Thu Aug 16, 2012 8:39 am
by Dwight Ennis
Right on!!! PROGRESS!!!
Re: Eureka Project
Posted: Thu Aug 16, 2012 11:12 am
by Postwarbob
I might live long enough to see this project done. Get er done Jesse. Work is looking great.
Bob ..........
Re: Eureka Project
Posted: Fri Aug 17, 2012 3:19 pm
by jessebanning
I got the rocker arms done. The blanks were water jet cut then a rotary table operation then a trip to the lathe. I hope to have the valves done tonight.
Re: Eureka Project
Posted: Fri Aug 17, 2012 6:10 pm
by jessebanning
Here is the rock shaft/arm assembly. A little clean up then paint. The last picture is the 1:1 Eureka.
Re: Eureka Project
Posted: Thu Aug 23, 2012 1:36 pm
by jessebanning
I got the piston rods done and the valves done.
Re: Eureka Project
Posted: Thu Aug 23, 2012 4:07 pm
by Harold_V
jessebanning wrote:I got the piston rods done and the valves done.
Milling with a drill chuck? (Third picture down).
Not really recommended.
Comments?
Re: Eureka Project
Posted: Thu Aug 23, 2012 4:18 pm
by joneg
i agree Harold, milling with a drill chuck is a recipe for disaster. i have seen them pop off the jacobs taper
