Good supplier of water gauge glass? 1/2" O.D
Re: Good supplier of water gauge glass? 1/2" O.D
tom_at_srclry_com
A student of the Southend RGS!
Also try Essex Brass. They make glass gauges and gauge cocks, etc. for boilers.
http://www.essexbrass.com/essex.htm
They should be able to help you out.
They make the gauge glass assembly on the engine I'm currently restoring.
You can also get 1/2" red line pyrex from Locoparts. We do not cut it, you have to need the specific lengths that we stock for our gauge glass assys. We have 2-7/8", 1-1/2" 4"/ 5". and 6" lengths. Call us at 757-255-2815. This way you are also directly supporting your steam loco vendors.
don
don
How about .200" diameter? So far no luck with McMaster, LocoParts, Blackgates, Stuart, etc. PM Research has 3/16" O.D. which is a bit too small. I'm still searching while also checking with friends. Many thanks, Bruce
Try looking for metric tube then. 0.2” is kind of an odd size, but it’s almost exactly 5mm.paralleler wrote: ↑Mon Feb 18, 2019 12:17 pm How about .200" diameter? So far no luck with McMaster, LocoParts, Blackgates, Stuart, etc. PM Research has 3/16" O.D. which is a bit too small. I'm still searching while also checking with friends. Many thanks, Bruce
-Tristan
Projects
Projects
Hi Tristan,
Yep..., I started to get the same idea:
http://www.livesteammodels.co.uk/shop/i ... ry&path=61
Many thanks, Bruce
Many thanks, Bruce
So the existing glass in the Stan James' Juliet was .200 inches in diameter. Turned out the drawing called for a 3/16" (.1875) so to cover our bases we've ordered both 3/16" and 5mm (.1968") replacement tubes. The 3/16" is coming from PM Research while the 5mm tube is coming from Live Steam Models in Great Britain.
Boy it's good to have friends. To Infinity & Beyond!
scratch around the glass with a dremel roto-wheel, crack it off...it will follow the scratch
wrap with some masking tape, chuck in a drill press or lathe chuck and polish the end square on silicon carbide cloth.
been doing this for 40 years....
need picture(s)???
need picture(s)???
Bill, Thank you for the tips. Another friend is preparing a 1-3/4" x 5mm tube and I'll be sure to get notes from him too.
My first experience with Live Steam Models of England appears to have gone well. They took PayPal, I didn't see an exorbitant processing fee for international banking, shipping/handling cost a bit more, and the order arrived in California within about seven days.
With my interest being 1" scale steam locomotives, most of my supplies come from England. I too, am a very satisfied customer dealing with several vendors from the UK.
David
David
Hi,
See if you can find a laboratory supply catalog on line. If you can, look for pipettes with the OD. you want. Many will even have graduation marks on the outside. Most pipettes will be low expansion borosilicate glass. Although it is quite unlikely, if you happen to get hold of tempered glass, it won't work.
To cut to length, use a 3 cornered file to make a mark on the outside of the tube, then put some spit on the mark. Bend the tube so the mark is on the outside. It will break cleanly at the mark. Note: In spite of what you might think, the spit is important. It works better than just plain water because the surface tension is lower.
Just one of the many simple things you learn when you work for a glass company for 30 years! I've posted this before, but I guess it doesn't hurt to do it again.
Richard Trounce.
Richard Trounce.
