Building the Southern Railway PS-4 Frame
Dave Bortz
Re: Building the Southern Railway PS-4 Frame
Post by Dave Bortz » Sat Sep 22, 2012 7:51 am
Hi Charlie;
For your first attempt, first part... I think it looks great.
Keep up the good work !!!
Dave
Pipescs
Post by Pipescs » Sat Sep 22, 2012 12:39 pm
I have been accused lately of being a nut case on the foundry effort.
Although it looks like I am becoming a foundry nut, I am actually only pursuing this effort to get the parts I can't locate in the 1.6 scale I decided to go with for the PS-4 Project.
I am hoping after the Trailing Truck and one more unique frame spreader to be able to put the foundry into storage until the frame is machined out and bolted together.
My son took these yesterday showing how I have reverted back to our caveman to Bronze age heritage. Waste oil and a Craftsman vacume cleaner is all you need. Well not really. I have invested in safety equipment too. The furnace is a beer keg
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
tailshaft56
Post by tailshaft56 » Sun Sep 23, 2012 10:32 pm
LivingLegend wrote:To insure consistent alignment of both frames bolted together....
I would drill and ream two holes for dowel pins in the frames.... Where those holes would be used to bolt the front footplate (or cylinders) at one end of the frame, and a crosstie at the other. This will spare you the headache of trying to get the frames back in perfect register should you, for whatever the reason, have to separate them before they are finished. It will also prevent a possible shift in alignment while machining them as well.
Use a .1875 dowel....This size will work out perfect if the bolts used to mount the footplate and crossties are #10 (.190). You will want a clearance fit in both frames for the pin. You can get by with a standard sized(.1875) reamer instead of the proper dowel clearance reamer.... The standard size reamer will cut enough oversize to clear the pin.
The holes for the bolts holding the frames together for machining should be match drilled after clamping them together.... Then match drill the holes for the dowels after you bolt together the frames.
Pick up a datum point on your frames once bolted together and mounted on your mill table. Then dial the table over to where the holes for the crosstie and footplate, or whatever are to located.... then drill for the dowel. Forget layout and center punching. Let the accuracy of the mill do the work for you.
Use a center drill or spotting drill as a start for your drill. You might want to consider the use of a split-point drill with a larger included tip angle instead of using a standard drill when drilling thru the thickness of both frames..
LL
I would recomend also laying out the holes. That way you know you are not a turn of the dial off. Never hurts to double check something.
Dennis
Thermal Arc 185-TS
Millermatic Challenger 172
Victor O/A
Atlas Craftsman 12 by 24 Lathe
Esab PCM-875
Wholesale Tool Mill-Drill
Pipescs
Post by Pipescs » Mon Sep 24, 2012 6:19 am
For the Journal Boxes
Have dreamed up a fixture that I will center up on the miling table and clamp the piece into. My DRO has a program where I can punch in the position of the 12 holes to be drilled. This way I can drill all the holes in all the journals at one time. (Plans are to cast four to six right now). This will also allow me to drill the six holes to mount the top plate which will also be silver soldered later
Then another fixture for boring the hole in the backside to mount the bearing plate.
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Pipescs
Post by Pipescs » Wed Sep 26, 2012 5:29 pm
Although not frame parts I went ahead and ordered a set of Pullman Car Trucks for the future. Hope to order a set any chance I get to put them back for when we get a chance to build the passenger train that the PS-4 engines pulled.
The casting set I ordered is also offered with the wheels but I opted to buy them next time I am up north and can get them home without shipping cost being so high
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Pipescs
Post by Pipescs » Wed Sep 26, 2012 6:25 pm
The sudden interest in Pullman Cars was motivated by seeing Dave Sclavi's train at Pa.
The plan is to farm these out to my son as he gets older. He has just started taking shop and is learning to weld having shown some interest in the lathe lately.
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Pipescs
Post by Pipescs » Wed Oct 24, 2012 6:40 am
In all my traveling I don't get as much done as I need to.
Earl Mueller has helped be by finding a large piece of pipe for my boiler which I will be dragging to Pulaski for the boiler project
In the mean time I sent a early attempt on a frame cross piece (too be Honest I was ready to throw in the towl as I had not put the draft into the parts) up to Trainman to see what he could do with it.
He sent me photos of this last night and will be having it cast at Cattail for me.
With these two items along with Trainmans pilot beam and smoke box cover I will be a little closer on my parts pile
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Asteamhead
Post by Asteamhead » Thu Oct 25, 2012 12:24 pm
Hello all!
Maybe some photos may help? Building the class A of the N&W I found the solution used with the prototype best for the model, too. Easy machining in combination with rugged but still precise tappered axle bridges made of lasered sheets gave best results. Fixing the tappered bridges by 4 vertical bolts of size M4 threads give a very reliable connection.
Asteamhead
Pipescs
Post by Pipescs » Tue Nov 20, 2012 4:37 pm
Although I have slid the casting work to the back burner I had a great day today in doing a set of castings for the side beams on the Hodges Trailing Truck.
I have attempted this part five times now and in the process I have added side runners to the pattern to help the metal get to the far in before setting up, used Graphite as a insulator, added thickness to the pattern in the long flat area to help with the run and used Copper Phosphor to thin the bronze down at heat. Today it all came together with the added fillets and thicker pattern.
Clean up is a bear as I have added a lot of vents or popoffs as I believe Dan calls them.
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Trainman4602
Post by Trainman4602 » Tue Nov 20, 2012 4:46 pm
Charlie
Congratulations on finally getting them cast. Your casting doesn’t look any more unusual then that from most foundries’. You only see the finished product. They have to add the same runners that you have added in order to get what the industry calls a sound casting. Keep up the great work.
tailshaft56
Post by tailshaft56 » Wed Nov 21, 2012 9:59 am
Great job on the castings Charlie. Keep up the good work.
Dennis
Thermal Arc 185-TS
Victor O/A
Esab PCM-875
RICHK
Post by RICHK » Fri May 27, 2016 1:35 pm
Hello Charles,
Have you an update to report since Sept 2011?
Also I am looking to find more drawings to fill in all the gaps in William Fitt's booklet starting with the steam cylinder / smoke box saddle for example.
That booklet is only a tantalizing insight into what might be available somewhere.. Can you direct me to a source?
The Smithsonian perhaps.
Regards,
Rich
