The Home Machinist!
It is currently Fri May 24, 2013 9:58 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: Thu Nov 03, 2011 12:18 pm
Offline
Tom Miller wrote:
Got mine from a friend and I don't know where he got it. But a quick google search came up with several sources.
Tom
Tom,
I did do some poking around after posting and found it on mcmaster.com for 9 bucks a quart.
Thanks again.
_________________
Visit my website here.
Top
 Profile
PostPosted: Thu Nov 03, 2011 12:31 pm
Offline
cbrew wrote:
Good Morning Tom,
Where can I purchase glycerin?
Chris
try your local grocery store. it's usually located where the alcohol is kept.
_________________
Fred V
Pensacola, Fl.
home track:
http://www.waleswest.com
Top
 Profile
PostPosted: Thu Nov 03, 2011 12:38 pm
Offline
Fred_V wrote:
cbrew wrote:
Good Morning Tom,
Chris
You know, I was thinking of that, so when i am ready i will give the local store a visit
Thanks again
Chris
_________________
Top
 Profile
PostPosted: Thu Nov 03, 2011 12:42 pm
Offline
jtdute wrote:
Thanks for the information Tom, Rich and Paul. That is exactly what I was looking for and pictures are worth a thousand words. I have used the displacement lubricators with the sight glass in the past with mixed opinions. I used salt water instead of glycerin, the salt water was denser than glycerin thus smaller oil drops. The one problem that I ran into is that I would lose or blow out the salt water solution from sight glass. The one reason I have been contemplating a mechanical lubricator is that the pump will be on a governor and I did not want the steam line to fill with oil when the pump was not operating. Tom, have you had any issue with this? Rich, how long does the reservoir in your lubricator last? I figure it would last good amount if it only advances 1 paw per up stroke. Again, thank you.
Jeff
i designed the attached pressure feeder to send oil to a sight glass which has a needle valve built in for control. i use this with 2 sight glasses for the cyl. luber on my Chloe but it would also work well for an air pump. the piston would get steam press. from the air pump supply line so it only works when the pump is running.
_________________
Fred V
Pensacola, Fl.
home track:
Top
 Profile
PostPosted: Thu Nov 03, 2011 3:15 pm
Offline
Rich, have you had any problem with hydraulic lock on pump when the governor shuts the pump down? I have also toying with what to do with the exhaust. I have concerns of routing the exhaust into the smokebox and into the exhaust stand due to amount of water from the steam condensation. Has anyone seen this issue or am I over paranoid. I am leaning towards just placing the exhaust line down and angled out at the pump. Any thoughts?
Jeff
Top
 Profile
PostPosted: Thu Nov 03, 2011 3:58 pm
Offline
cbrew wrote:
Most any pharmacy will have it. It's a primary ingredient in many hand lotions.
_________________
Greg Lewis
Eyeball Engineering — Home of non-interchangeable parts
Our motto: That looks about right.
Turning perfectly good metal into bits of useless scrap since 1983.
Top
 Profile
PostPosted: Thu Nov 03, 2011 6:26 pm
Offline
I would not worry about the condensation. I have my exhaust into the smokebox. Yes it does throw out a bit of water when you first startup but it never locks.
The best bit is the sound of the pump just ticking over when the loco is standing in the station,just keeping the air at the right pressure, really satisfying.
As I have just retubed the K36 I thought I'd share a pic of the refurbished smokebox - you can see the blower feed and the smaller exhaust feed to the manifold from the air pump. The whole setup is a bit crude but seems to work well.
Paul
Top
 Profile
PostPosted: Thu Nov 03, 2011 7:57 pm
Offline
Jeff,
Hydraulic lock? Never. In fact a pump can run on water. Slooowly.
Here's the secret on Westinghouse Pumps. Full size air pump systems and model air pumps too.
Reading the various treatises on Air Brakes there is a warning regarding a drain hole on the
Governor that must be kept clear to atmosphere. That is a leak !! See diagram "c".
Its primary purpose is for draining the air trapped under the air valve "b" to allow the steam
valve "26" to rise. A secondary function is when the air valve rises to shut the pump down
when the Main Res is up to pressure. Now there is a direct leak thru from the res.
This ensures the pump is cycled on to keep it hot. At the same time, if you look closely
at the diagram "f" there is a steam leak drilled thru the steam valve to also cycle the
pump slowly. On the miniature governor the "c" leak is just a scratch on the sealing surface!
For the steam leak, I added an adjustable stop (see the small valve wheel) to crack open
the governor just enough to keep the pump ticking over slowly.
Someday I'll find out what size hole that represents and drill the steam valve then plug
the adjuster.
Keeping the pump hot minimizes condensation and also keeps the water accumulation
blown out.
If the above is clear as mud, I'm doing good. :lol:
RichD
Jeff
_________________
Happy Rails !
RichD
Colorado Midland Ry Ten Wheeler U/C
Kerr Stuart Wren NG 0-4-0 U/C
www.csppry.org
Imagination is your best tool.
Top
 Profile
PostPosted: Tue Jul 31, 2012 7:14 pm
Offline
Below are a couple of pictures of the air compressor I completed except for the cylinder drain valves. They just arrived from COLES today. I decided to wait to install them, they are 1/8" copper tubing which with my luck would get damaged multiple times before I finish the engine.
I tested the air pump today. I used a cylinder I had which was ~316 cubic inches for a test reservoir, the locomotive reservoir is ~260 cubic inches. The air compressor pumped the test reservoir up to greater than 80 psi in about 10 minutes. The pump ran great with no issues. In one picture I placed the compressor on the boiler mounts just see what it looked like. As soon as I get the mounts painted the compressor is ready to mount for last time and finish the plumbing. Hope everyone enjoys, Thanks for everyone's advice from the forum. Jeff
Top
 Profile
PostPosted: Wed Aug 01, 2012 12:49 am
Offline
Who patterned that pump?
Its the closest to scale I have ever seen.
_________________
Narrow Gauge Exchange FORUM dot com
Loco112
Top
 Profile
PostPosted: Wed Aug 01, 2012 1:47 am
Offline
Greg_Lewis wrote:
Corn Huskers is, I think, just glycerin.
_________________
Top
 Profile
PostPosted: Wed Aug 01, 2012 6:35 am
Offline
The castings for the pump are from Richard Ulin of Ulin Locomotive Works. He offers the castings as a non functioning pump, however they can be made to work. There were a few issues that had to delt with to make it work. That was a fun little project.
Jeff
Top
 Profile
Who is online
Users browsing this forum: 10 Wheeler Rob, Mike Green, ref1ection and 8 guests
Search for:
Jump to:
