h2ogasnz wrote:
From the front of the chassis it is 14 3/8" to the C/line of the front axle and then it is 13 5/16 "to the C/line of the rear axle. Front axle box opening is marked as 3 3/16" high by 2 1/2" wide the height of the axle C/line is marked as being 1 1/2" above the bottom of the chassis.
When you have found the Center point for the rear axle ( 1 1/2" above the bottom of the chassis ON the axle C/line) you mark a line that is 2 5/8" above the bottom of the chassis in the area where the cylinder will be. Next draw a line from the rear axle center point that meets the line in the cylinder area that is 2 5/8 above the bottom of the chassis, this line has to be 20 13/16 long.
Jeff,
Thanks for the response. This is what I was interested in. The plans and the book don't actually say that the centerline for the cylinders is 1.5" from the bottom of the chassis. They draw a line 1.5" up from the bottom, but they drew it in the
other horn area, which in my mind was a bit confusing if not stupid. I was going to try and scale the plans to see if that 1.5" shown in the leading horn area was the same dimension as the starting point for the cylinder centerline, but then realized that the drawings probably shouldn't be scaled from. I couldn't see any other reason to draw the 1.5" line from the plans, so I sort of hoped it was the answer to my question.
Thanks for your help!
