The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Wed May 22, 2013 2:32 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: Machining bronze bearing
PostPosted: Sat Mar 17, 2012 12:38 pm
Offline
I need to create some special spacing washers and thought I'd just slice of pieces of a bronze bearing. What type of bronze sleeve bearing is easiest to machine? Standard Bronze or Sintered Bronze? I wonder if sintered is due the self-lubricating note in the description.
Thanks,
-Richard
Top
 Profile
PostPosted: Sat Mar 17, 2012 12:40 pm
Offline
Or how about this bad boy?
http://www.amazon.com/Nom-I-D-Bunting-B ... B002HAZ3CG
I just need to part off the washers, maybe have to take down the OD just a hair...
Top
 Profile
PostPosted: Sat Mar 17, 2012 2:00 pm
Offline
OK... Here's the drill...
First, Oilite (sintered bronze), also known as 841, is porous. If an Oilite bushing is to be machined from solid Oilite stock, it takes some knowledge and expertise as to how to machine it in order to retain the material's porosity on it's machined surface(s) and, therefore, it's lubricating ability. The same holds true if one is re-machining an off the shelf Oilite bushing, whose metal powder has been formed in a die to it's specified dimension and then sintered to fuse the powder together. You CANNOT use a tool bit that has a radius on it's tip.... The tool bit MUST have a sharp tip. Boring is best, but if you must use a reamer to bring it to size, make sure the reamer is one that is sharp. Preferably new.
Secondly, Oilite WILL NOT stand up to the pounding action experienced in main/side rods, or valve gear rods. The reciprocal motion will result in the bushing's ID being beaten egg shaped in short order. Many have used Oilite for axle bearings. If one must use Oilite in this application, it's best that they not be used on the drive axles.... For the reasons I just mentioned regarding their use on the main/side and valve gear rods.
Use 660 (also known as 932) bearing bronze. Phosphor bronze would actually be the better choice for rods and valve motion (as well as the prototypical "half-brasses" used for axles bearings.) But 660 is what the majority of readily available, pre-sized bushings will be found to made of. 660 bushings, as well as raw, un-machined round stock is also more readily found at most bearing supply houses than phosphor bronze.
If you are thinking of machining a spacer from a pre-sized bushing, personally, I'd use one made from 660 instead of one made from Oilite. You can get by with the Oilite, tho... But what's the point? The odds are, unless you machine it properly, and using tooling with the correct tool geometry, you will close up the side bearing surfaces and lose the spacer's self-lubricating ability. 660 would be a much sturdier material to use. And 660, unlike, say, a bronze such as aluminum bronze, is very easily machinable.
LL
EDITED..... 03/17/2012 @ 1416 hrs CDT
_________________
Last edited by LivingLegend on Sat Mar 17, 2012 11:03 pm, edited 2 times in total.
Top
 Profile
PostPosted: Sat Mar 17, 2012 2:36 pm
Offline
Perfect! Thanks!
-Richard
Top
 Profile
PostPosted: Sat Mar 17, 2012 7:03 pm
Offline
BTW: Regarding my mention of the use of Oilite for axle bearings..... Many have used them for this purpose. Me? Personally, I wouldn't.
LL
_________________
Top
 Profile
PostPosted: Sat Mar 17, 2012 10:03 pm
Offline
Yeah, oilite is bad news on rods and crosshead wrist pins especially.
The pounding breaks them up.
Solid bronze against polished steel is superior. Almost as good as ball bearings.
OTOH, Delrin (acetal) or better DelrinAF is great for rod spacers. Never wears out.
Also ideal for wrist pins. Might even do good for cranks too, but I have not tried
it in that location yet.
RichD
_________________
Happy Rails !
RichD
Colorado Midland Ry Ten Wheeler U/C
Kerr Stuart Wren NG 0-4-0 U/C
www.csppry.org
Imagination is your best tool.
Top
 Profile
PostPosted: Sat Mar 17, 2012 10:08 pm
Offline
RichD
i've been running Delrin on the side rods of my Chloe for several years. it seems to be holding up nicely. the crank pins are 16 years old and egg shaped but she runs quiet.
_________________
Fred V
Pensacola, Fl.
home track:
http://www.waleswest.com
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Gugger, LVRR2095 and 5 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
