The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Fri May 24, 2013 11:06 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Thu Apr 05, 2012 9:31 pm
Offline
Stove top pressure cookers are always aluminum, why?
Being a long time livesteam fan, aluminum seems like the worst material for a pressure cooker, yet 99% of them are cast or forged aluminum.
Water, pressure, steam, salt, other corrosive spices and minerals, those all sound detrimental to a boiler, yet our grand mothers all have pressure cookers that are older than she is, they each have been through hundreds of super-fast heat pressure and cooling cycles, that would be considered excessive & abusive to any livesteamer, yet these things still look brand new.
(I know its sounds ridicules, as we are all steel and copper boiler thinkers, but just for the sake of this exercise, lets pretend like it sounds perfectly normal).
Why not 100% aluminum boilers, tubes, stays, all of it?
_________________
Narrow Gauge Exchange FORUM dot com
Loco112
Top
 Profile
PostPosted: Thu Apr 05, 2012 9:45 pm
Offline
they only operate at 15 PSI. same as your car radiator. scuba tanks hole 3500 PSI but they are 1/2" thick and don't see any heat. pressure cookers will blow up if the safety valve sticks.
_________________
Fred V
Pensacola, Fl.
home track:
http://www.waleswest.com
Top
 Profile
PostPosted: Thu Apr 05, 2012 10:06 pm
Offline
I'm pretty sure my mom's circa 1948 pressure cooker was stainless steel but our circa 1968 model is aluminum. I believe a big reason for aluminum vs SS is cost - and you couldn't get them in that cool avacado color that ours came in. :lol:
Top
 Profile
PostPosted: Thu Apr 05, 2012 10:23 pm
Offline
Okay,
A properly designed and welded aluminum boiler operated within the limits of its design, and (key part coming up),
being completely disassembled, cleaned, and dried inside and out after every run may just be fine.
As far as getting water to boil at 15 psi, haven't done the math. I do know you can get radiator water hell-hot to the point you are in serious danger if you remove the cap.
Then again, I have seen steam escaping around the pressure valve on my pressure cooker.
Lots to chew on here for the engineers in the bunch.
However, I go back to my initial statement. Scrub all of the beans out after every use and it very well may last a good while.
Top
 Profile
PostPosted: Thu Apr 05, 2012 11:17 pm
Offline
I would guess that they are made out of aluminum because of the weight. A cast iron or copper pressure cooker would weigh quite a bit, add to that the contents you are cooking and you have to be a pretty hefty granny to put that on the stove.
Phil
_________________
"I used to be a rocket scientist, now i am just a space cadet"
http://www.SouthernCaliforniaLiveSteamers.com
RMI 3.75" scale Prairie 2-6-2 under construction.
View Progress
http://www.southerncalifornialivesteame ... nstruction
Top
 Profile
PostPosted: Fri Apr 06, 2012 7:03 am
Offline
My pressure cooker is stainless with an aluminum bottom bonded to the outside of the pressure vessel for heat distribution. Not overly heavy for it's size.
Rick
Top
 Profile
PostPosted: Fri Apr 06, 2012 7:07 am
Offline
makinsmoke wrote:
Okay,
a pressure vessel raises the boiling point of water. the 15lb safety lets the water get to 250deg. before it boils. in our boilers the water is at 340deg. when it boils. in either case if the pressure is suddenly released all that water will instantly flash into steam. that is what your radiator is doing.
_________________
Fred V
Pensacola, Fl.
home track:
Top
 Profile
PostPosted: Fri Apr 06, 2012 7:50 am
Offline
Leave water in your aluminum pressure cooker for a few days...it will be pitted and growing white cottage cheese. Pressure cookers last because they are washed and dried immediately after each use.
Keith
Top
 Profile
PostPosted: Fri Apr 06, 2012 10:26 am
Offline
You can use cast Al for boilers:
http://www.stationroadsteam.com/archive/1995.htm
There you go...
Note: I am unsure as to the limits of the offer to deliver via Dak, and ensure you bury the parachute on recept !
James
Top
 Profile
PostPosted: Fri Apr 06, 2012 12:28 pm
Offline
Unlike steel, AL loses at least half it's strength as soon as you weld it. I don't think it matters what metal you make a boiler out of. With the right combination of chemicals, and time, any metal will corrode. Interesting discussion.
Eric
Top
 Profile
PostPosted: Fri Apr 06, 2012 3:57 pm
Offline
While true to a point, depending on the alloy, it can be restored by being given a full solution anneal, then allowed to age, or artificially aged.
Notwithstanding, aluminum wouldn't make for a very good boiler due to its inherent ability to return to the substance from which it came, aluminum oxide.
_________________
Top
 Profile
PostPosted: Fri Apr 06, 2012 4:11 pm
Offline
Phil
You should have seen my Granny. A farm wife during the Depression, she did all the cooking and baking on a cast iron wood stove including all the canning needed for a family of eleven people, and everything else that needed to be done on a self-sufficient farm. She was stronger than some of the men. While she was the nicest granny in the world, she could have taken out a logger if needed.
_________________
Greg Lewis
Eyeball Engineering — Home of non-interchangeable parts
Our motto: That looks about right.
Turning perfectly good metal into bits of useless scrap since 1983.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Majestic-12 [Bot] and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
