gcarsen wrote:
The large railways guns where operated with a shell and seperate powder bags for the propellant. with basically a huge blank shotgun shell to ignite it all.
so you could use a .22 blank?
to cut the breach threads? it might be worthwile to look at cutting them in with an EDM sinker. you could rough in everything you can with lathe and mill work. make seperate electrodes for each of the 4 sizes of threads, sink them individualy, index the breach, move over the coresponding pitch dimension and sink again. make a set of plug and ring gages for each size, cut them into the portions you need and double check everything.
the electrode could be sandwiched up with the 4 threads, so you only have to index 4 times, plus however many cleanup passes you would need to bring it in.
getting the seal on the nose to the barrel could be interesting, you dont want any gas leak back into the threads!
Gcarson, From Wikipedia a 14" gun would be 53.5' long, so in 1/8th scale that barrel would be a little over 6.5 feet, and the bore would be 1.75" diameter. Using a 22 round may be ok if this thing were to be built in Oguage or something but for 1.5" to the foot it just won't cut it!
As for using an EDM sinker, most of the ones I have ever seen are vertical arrangements. Once again finding one large enough to fixture such a barrel I would think would be a challenge in and amongst itself. I believe that the threads must have been turned into the back end of the actual barrel to handle all of the blast pressures and reactionary forces.
This would be one cool piece of machining if done up right. I still wonder though I know I have seen on TV collectors of military artillery, tanks etc... and I thought they can really shoot them. How are civilians able to own those? I would think that would more or less be along the lines of what this barrel would amount to anyhow.
