Books on live steam
Books on live steam
A posting and a further conversation with Whitey had both of us thinking: We could use a thread on what books are out there for the live steamer. I have a bunch, so I looked them up and that led to more and to more.
So here's a list to start with. Add as you see fit. Books on machining should probably go in a thread in the General forum.
The first one is the book that got the whole discussion started (while technically, not about model engineering, I think that it's a must read):
'LBSC' HIS LIFE AND LOCOMOTIVES
http://www.amazon.com/LBSC-LIFE-LOCOMOT ... 685&sr=1-1
Simple Model Locomotive Building introducing LBSC's TICH
http://www.amazon.com/Simple-Model-Loco ... 816&sr=8-1
Betty The Mongoliper 2-6-2 3.5' Gauge
http://www.amazon.com/Betty-Mongoliper- ... 845&sr=1-7
Princess Marina LMS 2-6-0 Mogul 3.5' Gauge
http://www.amazon.com/Princess-Marina-2 ... 845&sr=1-8
Speedy GW 0-6-0 Tank Engine 5' Gauge
http://www.amazon.com/Speedy-0-6-0-Tank ... 845&sr=1-6
The Live Steam Book
http://www.amazon.com/Live-Steam-Book-L ... 463&sr=1-4
'Maisie' - Words and Music
http://www.amazon.com/Maisie-Words-L-LB ... 463&sr=1-5
LBSC`s Famous 4-4-0 Virginia Live Steam Locomotive Construction
http://www.amazon.com/LBSC%60s-Famous-V ... 514&sr=1-1
Manual of Model Steam Locomotive Construction by Martin Evans
http://www.amazon.com/Manual-Model-Stea ... 556&sr=1-1
The Model Steam Locomotive: A Complete Treatise on Design and Construction
http://www.amazon.com/Model-Steam-Locom ... 556&sr=1-4
Model Steam Locomotives Henry L. Greenly
http://www.amazon.com/Model-Steam-Locom ... 608&sr=1-2
Building the Shay by Kozo Hiraoka (Jun 1982)
http://discoverlivesteam.com/books/shay.html
Building the Heisler by Kozo Hiraoka (Jun 1986)
http://discoverlivesteam.com/books/heisler.html
Building the Climax by Kozo Hiraoka (1989)
http://discoverlivesteam.com/books/climax.html
Building the New Shay by kozo hiraoka (2007)
http://discoverlivesteam.com/books/newshay.html
The Pennsylvania A3 Switcher by Kozo Hiraoka (2001)
http://discoverlivesteam.com/books/penn_switcher.html
Civil Engineering for Outdoor Railroads
http://discoverlivesteam.com/books/civi ... ering.html
Falk No. 1 Locomotive
http://discoverlivesteam.com/books/falk.html
How (not) to paint a locomotive
http://discoverlivesteam.com/books/pete ... paint.html
So You Want to Build a Live Steam Locomotive?
http://discoverlivesteam.com/books/SYWTBALSL.html
MODEL LOCOMOTIVE VALVE GEARS - M.EVANS
http://shop.ajreeves.com/model-locomoti ... -450-p.asp
MODEL BOILERS & BOILER MAKING
http://shop.ajreeves.com/model-boilers- ... -459-p.asp
LOCOMOTIVE VALVES AND VALVE GEARS
http://shop.ajreeves.com/locomotive-val ... -464-p.asp
MAINTENANCE & MANAGEMENT OF SMALL LOCOMOTIVES
http://shop.ajreeves.com/maintenance--m ... -442-p.asp
ROB ROY & WILLIAM
http://shop.ajreeves.com/rob-roy--willi ... -445-p.asp
Painting & Lining Models by R.C. Rogers
Beginners Guide to Model Steam Locomotives by T. Coles
Model Boiler Making by E.L. Pearce
Laying Out for Boiler Makers Lindsay
Model Boilermaking, Design & Testing - Pearce
Model Locomotive Boilermaking - Farmer
Walschaerts Valve Gears - Greenly
The Live Steam Book
ROB ROY & WILLIAM
Re: Books on live steam
Steve thanks a lot for the list. It will help a bunch. Whitey
"Building Small Steam Locomotives, A practical Guide to Making Engines for the Garden Gauges" By Peter Jones
http://www.amazon.com/Building-Small-St ... pd_sim_b_5
The Valve Gear design book (originally two books) "Design Procedures For Walschaerts & Stephensons
Valve Gears" by D. L. Ashton are a valuable source on info. His notes clear the air on the mysteries
of valve gear designs.
http://www.teepublishing.co.uk/
Also, being as we are neccessarily machinists, don't forget the "Machinery's Handbook".
The machinist's Bible. Any of the older second hand editions will do very well.
RichD
RichD
Happy Rails !
RichD
Colorado Midland Ry Ten Wheeler U/C
Kerr Stuart Wren NG 0-4-0 U/C
www.csppry.org
Imagination is your best tool.
RichD
www.csppry.org
Any live steamer would enjoy 'Master Railroad Builder' by the late Steve Booth. ISBN 0-941178-03-X
Lots of people the west coasters will know, and lots you won't. (I'm on page 255 )
John Brock
Wow !! that book is not cheap. What does it cover just different pic's or does it get into building and construction etc. It seems in this modern age. You can't even see the table of contents. Whitey
It was expensive when new, so I guess it makes sense it is expensive now. I didn't realize it was quite that expensive though. I probably wouldn't buy one sight-unseen Whitey, but someone in a club around you might have a copy they'd let you take a peek at. I would describe it as an 'inspirational overview' of the larger gauges (7.25" and up, there's not much on sizes below that). It is definitely not a 'how-to', but more a heavily-illustrated survey of what's been done. Here is a chapter list:
1. Roots of Steam
2. Disney Magic
3. Centerville & Southwestern -- two inches of cream
4. Scale and Gauge
5. Tipsico Lakeshore - the semi-scale approach
6. Narrow Gauge
7. Diesel Designs
8. Craftsmanship in Steam
9. The Electric Connection
10. Rolling Stock
11. The Right Track
12. Bridges and Tunnels
13. The Structural Touch
14. Signals and Communication
15. Wabash, Frisco & Pacific
16. Playing the Railroad Game
1. Roots of Steam
2. Disney Magic
4. Scale and Gauge
6. Narrow Gauge
7. Diesel Designs
10. Rolling Stock
11. The Right Track
John Brock
John thank you very much. Whitey
Just for information. I got a book off E-bay MODEL STEAM LOCOMOTIVES by Greenly's and revised by Ernest Steel.A very,very informative book for a novice with Lot's of drawings etc. I think great for twenty bucks. Whitey
Of all the books on the list, the first one I would get would be Joe Nelson's "So You Want to Build a Live Steam Locomotive." The next book I'd recommend isn't a book. If you can pick up any copies of Don Young's magazine, "Locomotives Large and Small" I'd grab them.whitey wrote:Steve thanks a lot for the list. It will help a bunch. Whitey
Good first book. Covers a lot of the non-construction questions for the novice that you won't find anywhere else, as well as construction.Marty_Knox wrote:Of all the books on the list, the first one I would get would be Joe Nelson's "So You Want to Build a Live Steam Locomotive." The next book I'd recommend isn't a book. If you can pick up any copies of Don Young's magazine, "Locomotives Large and Small" I'd grab them.whitey wrote:Steve thanks a lot for the list. It will help a bunch. Whitey
Even if you are not building one, I would recommend:
It's interesting (in LBSC's witty British style) and has a lot of good information for the novice.
I'm just finishing up Kozo's Pensy switcher book. Also good for the novice, but he doesn't go into as much detail as LBSC does on each part.
Thanks Steve and others. Have started to ge a couple of them in including the shop shed and road. and they sure help a novice. Thanks again. Whitey
