Elesco pump drawings
Re: Elesco pump drawings
Also doesn't CN 47 fit into the list of Elesco equipped locomotives at Steam Town?
3/4" scale LBSC Bantam Cock
3/4" scale B4 project (re-designed LBSC Juliet)
- Stuart T. Harrod -
I have an ELESCO feed water heater booklet 44 pages that has a lot of drawings and information on the pumps, heaters and related parts also part lists. I have it scanned into my computer and can supply print outs. If Interested contact me.
LSGOD
LSGOD
As Promised. It seems that all of the pumps on the engines at work are CF-1 except for the 2929. See below
Bruce Mowbray
Springville & Southern RR
Elesco CF1 Pump on the 6039
Bruce Mowbray
CF1 On the CN 3254
Bruce Mowbray
CF 1 on the CN 47 with piping. Note, this one is missing the cylinder head on the left cylinder.
Bruce Mowbray
Here's an interesting one. A CF-0 on the CP 2929. Essentially 1/2 of a CF-1. Also, the heat exchanger bundle is completely inside the smoke box with the plumbing entering in the lower left hand portion of the smoke box.
Bruce Mowbray
And finally, the mounting bracket of the CF1 that is on the CN 3377
Bruce Mowbray
Thank you so much Bruce! This really helps me! Why is the 47 missing a pump head? Isn't that damaging the exposed inside? Also how did Steam Town weather out the storm?
LSGOD: I would love those pages! This is very nice of you! I think Allen might be interested in the book too!
The side of the pump that is missing the head has been covered with a piece of sheet metal. If the pumps are ever put back into service, they are given a complete teardown and refurbishing. Steamtown had no damage from the storm. There were a few trees knocked down out on the main line and those were cleared quickly. No washout damage.Stuie wrote:Thank you so much Bruce! This really helps me! Why is the 47 missing a pump head? Isn't that damaging the exposed inside? Also how did Steam Town weather out the storm?
Bruce Mowbray
Great pics Bruce! Thank you for posting them!
That single cylinder pump is interesting. I knew Elesco made the CF-2, but not the little one.
I was going to say that the pump with the missing head was most likely covered in some way. The stack does have a cover on it. The locomotive looks a little rough. The head was most likely cannibalized to use on another pump.
When I worked for NS; we never left things open. There are only so many of these parts still in existance.....not like 70 years ago. If the castings are sound; they can be made to work again.
Andy Pullen
Andy Pullen
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30", Sanford MG 610 surface grinder, Kalamazoo 610 bandsaw, Hardinge HSL speed lathe, Hardinge HC chucker, Kearney and Trecker #2K plain horizontal mill, Haas TL-1 lathe.
- joeburgard540
See attached photos for diagrams of the Elesco CF-1 pump. From the 1929 "Elesco Locomotive Feed Water Heaters: Operation and Maintenance" booklet.
Hope this is useful to someone.
