Don Young's "Lucky 7" 2-4-4
steamfreak22
Post by steamfreak22 » Wed Dec 19, 2012 8:47 pm
Hello again,
I got some questions for you all...
Does anyone have experience with building the 7.5" gauge version of Don Young's "Lucky 7" Forney? I also would like to know if anyone had done a conversion from the 3.5" gauge wheel base to the 7.5".
Any tips and tricks?
Thoughts about it as a 7.5" gauge locomotive?
Owners speak up! :D
Enjoy the Holidays!
David W.
LivingLegend
Re: Don Young's "Lucky 7" 2-4-4
Post by LivingLegend » Wed Dec 19, 2012 8:58 pm
Not sure what you mean...
But, Don Young also had, and made available drawings and castings for a Maxi Lucky 7.... Which in 3-3/4" scale and ran on 7.5 gauge track. No need to convert.
Don't know who sells drawing and castings fo the loco these days.
LL
Do it right.... Or don't do it at all
I have no life. Therefore, I have a hobby
It's not that I'm apathetic, I just flat don't care
An Intellectual is nothing more than an Over-Educated IDIOT
Blogs: Where people with nothing to say..... Say it
hwboivin3
Post by hwboivin3 » Wed Dec 19, 2012 9:30 pm
Original design was for 3 different scales. Outside frame for 3-1/2 gauge or inside frame for 7-1/2 gauge. These used the same parts just modified for the frame location. Then the 2nd dimension was the maxi lucky 7 which was the out side frame for 7-1/2.
A guy in our club is building an electric maxi 7 . I saw lots of pictures plus his rear truck with plum cove motors installed. Also, in the archives of Stationroadsteam.com there are some and I do believe one of them is the inside frame version for 7-1/4 gauge.
Hope this helps.
Harry
Here's the link
http://www.stationroadsteam.co.uk/stock ... /index.htm
johnpenn74
Post by johnpenn74 » Wed Dec 19, 2012 9:38 pm
Isn't Steve Alley making casting for that again? One of the vendors at Train Mountain 2012 had some.
Also member of Blueridge Live steamers in Virginia has one too.
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
hwboivin3
Post by hwboivin3 » Wed Dec 19, 2012 9:44 pm
I think Steve has castings for SR&RL #24
AJReeves has lucky 7
Loco112
Post by Loco112 » Wed Dec 19, 2012 10:59 pm
hwboivin3 wrote:I think Steve has castings for SR&RL #24
I sure would like to see those!
Narrow Gauge (Information) Exchange dot Org forum
My Projects:
Davenport 30 ton diesel (SV#101 / D&RGW#50)
C&S 1908 steel & 1905 wood: box, stock, flat, gon
D&RGW wooden freight cars, long & short cabeese
EBT 2-bay hoppers, Conoco #44 tank
DV (K&J) hopper
8"n3 - 3-footers, 8" scale, 24" gauge
David_T
Post by David_T » Thu Dec 20, 2012 11:59 pm
I think JB Reeves in England has castings. Used to be Reeves 2000, now new web site.
steamfreak22
Post by steamfreak22 » Fri Dec 21, 2012 12:52 am
Sorry if I confused anyone. I'll try again. (For LivingLegend)
The locomotive I am speaking of is Don Young's 1.5" Scale 3.5" gauge forney.
My question is....
Have any of you out the converted his 3.5" gauge Forney to 7.5" gauge?
I was told that you could move the wheels from the inside of the frame to the outside thus widening the gauge from 3.5" out to 7.5"
Hope that's a bit more clear. :D
Also does anyone have any insight on the performance of these little Lucky 7's?
David W.
Benjamin Maggi
Post by Benjamin Maggi » Fri Dec 21, 2012 8:58 am
I don't have any experience with the engine, nor with converting it. However, I think the forum members inquiries as to your intent are because they want to help answer your question better. Which situation below best describes the position you are in right now?
1. You already have a 3.5" gauge engine, and want to convert it to run on a larger gauge (7.25", 7.5") track?
2. You don't have an engine but want to build one, and would rather start with a 3.5" gauge plans then the 7.25" gauge plans? It seems from the response on this board that since both engines use the same castings if you were starting from scratch it would make sense to build it to the larger gauge from the onset, rather then building it to the smaller one and then converting it.
hwboivin3
Post by hwboivin3 » Fri Dec 21, 2012 3:39 pm
I don't know anyone who has done the conversion but it has been done. See link to stationroadsteam above. I am quite familiar with the blueprints and articles for it. And it was designed to do just that. It is a very good design as are all of Don's engines. The drawings and articles explain very well which parts go with what. For example the Maxi and the 3-1/2 gauge are identical in design, but there are differences with the converted inside frame engine. It's a little more than just relocating the frame.
David_T
Post by David_T » Sat Dec 22, 2012 12:44 am
If you access to a "Live Steam" magazine library, Don Young's construction article on the Lucky 7 starts in Jan 77 and runs thru Mar 80.
steamfreak22
Post by steamfreak22 » Sat Dec 22, 2012 12:49 am
Where I stand right now is I am looking at buying a 3.5" gauge Lucky 7, and I would like to convert it to 7.5".
Just want to check if people think it would make a decent 7.5" gauge locomotive.
David W.
