tsph6500 wrote:If it was vigorous boiling that is causing the dip, it would be possible to recreate the dip when the loco is stationary by over-firing.
If the phenomenon only occurs with throttle application it has to be due to the steam entering the dry pipe and leaving the boiler. Is the dry pipe located close to the pressure gauge fitting on the boiler? This might cause a situation similar to the gauge being plumbed to the turret, which we know is not correct practice.
I don't think this is correct, all the over-firing will do is raise the temp/pressure, not a lot of "boiling" going on,
the boiling happen as steam is drawn from the vessel,
which
1) lowers the pressure (every so slight)
2) water reacting to the drop in pressure, flashing to steam (causing the boiling) as equalization of the system accrues
the faster the draw, the more violent the reaction, as any one seen the reaction to a boiler if the safety valves are too big for the boiler? its an amazing shower for all around)
3) pressure is maintained as you apply more heat,
this thread to discussing water drop in the sight glass not the pressure gauge.
