Page 5 of 9
Re: Building a Power Model Water Pump
Posted: Mon Feb 11, 2013 9:11 pm
by John_S
Started on the steam gland tonight:
There's a very small internal bore for the o-ring that still needs to be done and then part it off:
Spent half the evening machining that and the other half making the tiny boring tool out of HSS. Tomorrow I should be able to bore that internal o-ring groove on this gland and machine up the gland for the water end as well.
Posted: Tue Feb 12, 2013 8:15 pm
by John_S
Still moving along...
Finished grinding my wee little boring tool to do the internal bore for the o-ring in the steam and water glands. Hate machining in a place where you cannot see the tool or what's happening!
The steam and water glands finished up, other than some light deburring and smoothing:
The glands temporarily installed in the spacer:
Wish I didn't have to work for a living. I'd get more done each night!
Posted: Fri Feb 15, 2013 9:22 pm
by John_S
Steam piston, machined from brass. I didn't have any 1.375" 303 stainless, which is what the print calls for. Brass will do:
Piston finished up:
The small reversing plates, one goes in the steam piston and the other in the head assembly:
And got started on the piston rod. Started with a piece of 303 0.250" SS which had to be turned down to .219"
Posted: Fri Feb 15, 2013 9:28 pm
by Bill Shields
you better get it very smooth and very straight and even.
that rod goes through an o-ring, and if there are any binds or leaks, the pump won't work.
if it is rough, it will wear the o-ring quickly and the pump won't run.
I admire your tenacity, but even with a CNC Swiss style (sliding headstock) lathe at my disposal, I just purchased a piece of ground rod.
Posted: Sat Feb 16, 2013 7:55 pm
by John_S
Bill Shields wrote:you better get it very smooth and very straight and even.
Actually, it goes through two o-rings, one in the steam cylinder gland and one in the water cylinder gland
Posted: Sat Feb 16, 2013 8:06 pm
by Bill Shields
ah...i thought it was the trip rod....sorry.
same concern....
Posted: Sat Feb 16, 2013 9:02 pm
by John_S
The trip rod I bought material that is already the correct dimension, so there should be no problems with it.
Bill, have you had a chance to snap a photo of your jig for machining the valve body yet? I've been holding off doing any work on it until I got a chance to see what you had come up with.
Thanks!
Posted: Sun Feb 17, 2013 1:31 am
by Harold_V
John_S wrote: Started with a piece of 303 0.250" SS which had to be turned down to .219"
Indications are you're using a C5 or C6 grade of brazed carbide. You'll have much better success using a C2.
Trust me on this one. I've machined several times my weight in 303 SS.
Posted: Sun Feb 17, 2013 7:18 am
by Bill Shields
Posted: Sun Feb 17, 2013 8:28 am
by Bill C
Bill, thanks for posting those photos! With a casting like that, I can sure see the utility of the box. Very neat idea, I have saved the photos in my "someday I will need this" folder!
Thanks again,
Bill C.
Posted: Sun Feb 17, 2013 8:45 am
by John_S
Harold_V wrote:Indications are you're using a C5 or C6 grade of brazed carbide. You'll have much better success using a C2.
The C5 is working nicely, but I'll give a C2 a shot on the next SS part and see how it goes. The piston rod turned out with an exceptionally fine finish on it.
Posted: Sun Feb 17, 2013 10:11 am
by Fred_V
John_S wrote:The trip rod I bought material that is already the correct dimension, so there should be no problems with it.
Thanks!
in the casting set I have Art Olds machined a brass block with all the holes and openings. He was going to cut a new flat head and silver the block to it. He thought that would be a lot easier than using the casting. I have the head casting so I would like to try making it; I can always fall back on the brass block.
