THE LAST PIECE OF THE PUZZLE
- Trainman4602
I just finished the last part needed to complete the K4. It is the water and oil separator for the air supply.
I used some hunks of scrap brass and a short piece of 1 ¼ drain pipe to make it.
The hardest piece to make was the flange and the cap. I made them both together and then saw cut them apart.
I don’t have a chuck for the rotary table so I used the super spacer to make the bolt lugs.
I did this by indexing it around eight times in different positions to make the lugs. Drilled the bolt holes and saw cut it apart. A little file work and a run thru the sand blaster and soldered it together.
I’ll paint it with DGLE and it’s done.
Re: THE LAST PIECE OF THE PUZZLE
Beautiful work Dave, must feel good to be near completion..
- Trainman4602
Thanks
The locomotive has been running for 9 years. I'm just now getting around to finishing some small details that I didn't get to finish.
Very nice, Dave!
- makinsmoke
Dave,
Now that the pieces are done, have you thought about making castings for sale?
Beautiful work.
Brian
Beautiful work.
Brian
Trainman4602 wrote:I just finished the last part needed to complete the K4. It is the water and oil separator for the air supply.
Do you have working aircompressors
Regards
Garry
Nice bit of work there, Dave.
- JBodenmann
Hi David
I must compliment you on your fine work. I have seen you K4s in person and photos can never do it justice. A good model locomotive has many little bits of jewelry like this. The more you look the more you see!
Very Nice!
Jack
Very Nice!
Jack
- Trainman4602
Thanks everyone for the wonderful compliments on my work.
Its good to know that your work is appreciated.
- Trainman4602
The last piece. Today I mounted the air Water & Oil separator. This the last piece on the locomotive.
Last week I degreased the engine and prepared it for a coat of Dark Green Locomotive Enamel, AKA Brunswick Green.
Now I have to move on to the tender. Some details to make such as the cutting lever brackets and rear tender steps. The rear steps are a bit tricky I’ll post something on them when I start.
Looks right at home all snug in there. Is this a functional separator, or just a detail piece?
- Trainman4602
Just Ginger bread
