Cleaning an engine?
Cleaning an engine?
I have a L.E. American that is such a pretty little engine but after a day's running it comes home all speckled with water marks and steam cylinder oil. I am wondering what I can use to wash the engine down before polishing the brass (with Brasso) and Turtle Waxing the painted surfaces.
Has anybody used automotive 'engine shampoo' and a steam engine? Just hot soapy water? What works and doesn't harm the paint?
What do others use?
click here
What do others use?
click here
Re: Cleaning an engine?
One of the most common practices I see is people attaching a homemade wand to the blowdown valve and just use the remaining steam pressure and hot water to clean the engine.
-Tristan
Projects
Projects
I believe, the best tool for cleaning engines is called "small children", there is only one bad thing about them...then they get clean in the bathroom, and leave the bathroom a mess !
No real good suggestions, although it has been kicked around on traction talk, as to various ways to clean full sized engines. Anything that _will_ remove the dirt, _may_ remove paint too...
James
James
WD40 and wipe it down.
John B.
John B.
Best method is to spray the engine with an air gun and diesel fuel. Use as much as you can and make sure the vapor cloud is visible from a satellite.
Just pre-clean the kids with a swimming pool...
Mattaniah Jahn
Matt Corps. Railsystems,
operating on the Manatee Central RR
http://www.flickr.com/photos/62441046@N06/sets/
Hello Dianne,
Use a strong concentration of simple greem in a spray bottle. Spray it down good.....let it work for a bit. Hose it down with water........low pressure compressed air to dry it off. Windex to remove sny streaks left by simple green. Wax and brasso to finish.......however......never dull works better on brass.
Pamela
Pamela
I use GUNK which I get at an auto supply store in a pressurized can to clean the mechanical parts and PLEDGE furniture polish to do the painted surfaces.
BTW - I don't clean my engine until I'm ready to go back to the track and run. Leaving the oil, etc. on the engine keeps it from rusting.
That was the job of my two brothers and me when we were kids. We washed up in the bathroom at PVLS.James Powell wrote:I believe, the best tool for cleaning engines is called "small children", there is only one bad thing about them...then they get clean in the bathroom, and leave the bathroom a mess !
Polishing with Brasso was done on the kitchen counter at home.
My mom said that if people knew what had been cooked in our pots and on our stove, and cleaned in our sink, they would never eat at our house.
- LivingLegend
Old timers used kerosene and a siphon blow gun nozzle.
LL
LL
Kerosene and a siphon blow gun are still used at CALS for the cleaning at the track.
Sorry, but I must disagree.James Powell wrote: Anything that _will_ remove the dirt, _may_ remove paint too...
Can you say Stoddard solvent? Mineral spirits? Neither will remove paint that is cured.
