Who sells reflex sight glasses?
Who currently sells reflex sight glasses for 1.5" scale? I know Bob Dean and Dave Sclavi, anyone else?
Thanks,
Jon
Thanks,
Jon
Re: Who sells reflex sight glasses?
Wayne Godshall
John B
John B
- Trainman4602
I have them for sale
For more details and the price go to the market place
My assumption is that this question is about reflex-style sight glasses, as opposed to the ones that actually have a prism on the front (?)
Dan Watson
Chattanooga, TN
Chattanooga, TN
Power Model Supply used to make them with the true reflex ground glass. I had one - I loaned it to Howard Gorin. He was going to make them, but it's been a long time.
Here is a picture of Bob Deans Reflex water glass.
From his web page:
1-1/8" x 3-1/8". Unit tested to 150 PSI. Loctite Thread Locker applied to all setscrews and nuts. Nuts torqued to 8oz/inch. Light is refracted at different wavelength so waterline and below appears darker to eye and liquid level is apparent at a glance. This unit has been scaled down from a Nathan Reflex Glass (minus night light and shield) and will give working water travel of about 2 inches. Bottom of glass should be .500" above top of crown sheet minimum.
Tim
From his web page:
Tim
I also have the Bob Dean glass in stock and ready to ship
I like them and had Jack put 2 on the Lackawanna Hudson
- Chris Hollands
Bob Deans are the best you can buy.
high jack the thread
Mike what are all the gauges for ,can you tell me what each is.
Chris
Chris
Chris
on top is 1 of 2 boiler preasure gauges, on the engineers side we have locomotive brake cylinder preasure and train line gauge, on firemans side we have steam chest preasure, vacuum indicator and water pump out put preasure...not seen and mounted on the tender is main res. air preasure
Mike
Mike
