0-4-0 sizes
0-4-0 sizes
Hey everybody,
I am going to continue the tradition of building an 0-4-0 as my first locomotive. (this is in 7 1/2" gauge) I was thinking of building a falk, due to the small size, but was turned off by the horror stories of poor steaming. Something a little bigger would be preferred, but not too big as ideally it should be able to be placed in the trunk of a small car.
To help it fit, i was considering modeling a low clearence steel works engine such as Steptoe Valley #3: http://history.nevadanorthernrailway.ne ... 09wurm.jpg
If it helps, #3 in 1.5" scale would have 1 1/x 1 3/4 inch cylinders and 3 3/4 inch drivers.
So the question is: What designs for small or medium sized 0-4-0's (in 1 1/2" scale) are out there? Any you reccomend? are there any that have specs close to #3?
Re: 0-4-0 sizes
The obvious answer is a Kozo A-3 scaled up to 1.5 inch. I'm sure you've looked into it, I just mention to make sure. I don't know what your experience is, but designing a loco from scratch is quite an undertaking, however simple it is. Using a design and drawings that are known to work should be a big factor in any choice.
Just my .02 : - )
Just my .02 : - )
Re: 0-4-0 sizes
Wait for Dave Sclavi to reintroduce the Reading A5 camelback. It's a smaller 0-4-0 and is an easy to build locomotive that will pull quite a few cars.
Little Engines also has an 0-4-0. It is larger than the camelback and will also pull quite a bit.
Andy Pullen
Andy Pullen
- steamin10
Re: 0-4-0 sizes
If you like the idea of an early engine like the Falk, (I do) then toy with the idea of eliminating the hoist junk, and extend the boiler for more capacity. It would have a 'family ' style look for the woods engine, and be noted as Falk #3 or some such excuse for your version of what could be. AFAIK, most everything about the frame, cab, and workings would be already there, just extend the boiler.
Thinkin' out loud.
Alternately, the Marie Estelle is a dimunitive engine of character with a 4 wheel tender. Lotsa ways to go.
Happy Steamin'
Thinkin' out loud.
Happy Steamin'
Re: 0-4-0 sizes
I'd second the question of if your going to design this yourself. If so then "it's done" and the story now changes to parts you will source to begin the construction. As for available 0-4-0s
Little Engines: 0-4-0: castings available
Little Engines: Crab?
RRSC: 0-4-0 B&O dockside or switcher: castings available
Allen Models: Chloe: castings available
Mercer: A5 Camelback: castings will be available
Kozo A3 Switcher: scratchbuilt from stock
All of these are "light" from an 7.5" gauge standpoint but your still talking at least 200lbs. Your not going "stuff" it in a trunk. My Kozo A3 is well over 200# and is not exactly easy to move around. I don't know of any small 7.5" gauge engines besides the Falk and maybe the Invicta that would easily drop into the trunk of a car. Everything else is heavy enough to where your going to need to roll it in/off a truck or station wagon. Invicta will pull you and another person around with no problem and WILL fit in your trunk.
If you don't mind British style locos, there was a neat article in LS in the early 2000s about an engine called "Dante" which was basically a stripped down and simplified "Tisch". I always found it charming. Never saw one in the flesh. It was small enough to drop into a trunk. $.02
Ken-
Ken-
Re: 0-4-0 sizes
there is a fellow here on the east coast that carries a Mercer Camelback around in a Subaru Forester.
It's a squeeze with the tender... but fits....
Re: 0-4-0 sizes
I carry a 7.5" gauge INVICTA loco, tender and two riding cars around in my Prius and still have room for myself behind the wheel and a passenger in the right seat.
Re: 0-4-0 sizes
Bruce Ward hauled his Invicta and a riding car + coal/Propane and tools all over the place in a late 1960s VW Square Back. 1967 I think. Replaced it with a small pickup when he could no longer get parts for the VW. Cary
Re: 0-4-0 sizes
Maybe you should describe exactly what you will be carrying the finished locomotive in, and how you intend to load/unload it. If you have to put something down into the trunk, then something about 150 pounds, lifted in and out by 2 adults, would be about the limit. If you have a hatchback, and can roll it in and out, then I wouldn't worry too much about the weight, just the size that you have to put it in.
One locomotive that I think would fit your bill very well is Jesse Livingston's Filer and Stowell 0-4-0. It was an odd prototype, built with oscillating cylinders, but most of the parts are pretty easy to make and it has no valve gear. Making the oscillating cylinders and the trunnions would be the toughest part of it.
If you want REALLY simple and small, Jesse Livingston also had a series for a small vertical boilered locomotive called 'newby', which was designed for a beginner to build. It would be small enough to handle pretty easily. Both of these were for 7 1/4" or 7 1/2" gauge. These were serialized in Live Steam several years ago, but you can purchase his book, and BOTH of them are in there.
Re: 0-4-0 sizes
Here's one I built in 1979.
It is a quick and easy build but still takes two to pick up.
I built it with a 10" Logan lathe, a 7" shaper, and a drill press.
It was re-designed from the LBSC Tich to 1 1/2" size by Charles Kennion.
Parts and drawings available from Kennion Bros. in the UK.
I have a set of Americanized plans for it called Twich.
http://youtu.be/JqIlyZ2ptY4
Fadal Turn, Fadal Vmc 15, Prototrak 16 x 30 Cnc Lathe, Pratt and Whitney 16 x 54 lathe, Pratt and Whitney Vertical Shaper, G & E 16" Shaper, B & O Electric turret lathe, 36" Doall band saw,
Enco B.P. Clone, Bridgeport CNC Mill, Delta 12" Surface Grinder.
Re: 0-4-0 sizes
As have 10,000 before it (and many of those without the shaper.)kapullen wrote:I built it with a 10" Logan lathe, a 7" shaper, and a drill press.
A very wise approach. One of the locomotives which I think would adapt well to your needs and can be Americanized easily are the Quarry Hunslets. There is a huge amount of information on this manufacturer and a number of designs in live steam, and can be built in inside and outside frames. Another basic design I can highly recommend, again British but easily Americanized, is Jessie by Ken Swan. Jessie is an adaption of his original design for Bridget which has been a popular and thoroughly proven design for decades in the UK. 5" drivers, 1-7/8" cyls, 6" boiler.KandCRy wrote:I am going to continue the tradition of building an 0-4-0 as my first locomotive.
GWRdriver
Nashville TN
Nashville TN
Re: 0-4-0 sizes
I don't think you'd be able get a Hunslet in the trunk of a small car. Even the 3" scale 'Elidir ' comes in at 36" long and 300lbs. With a tall chimney and cab I doubt you'd get the trunk lid closed. Yes, 'Jessie' is a great design and at 33" and 160lbs you could just do it with 2 guys. If you're limited to a trunk what about the 7 1/2" g. version of 'Tich' - you could probably lift it yourself but would still give a good account of itself on the track. Ray.
