Loctite 680
Loctite 680
How and what will remove the half hard residue from Loctite 680? Some of it ran down the side of my parts and is just a sticky residue on the side.
Re: Loctite 680
Try acetone....it works for me.
Keith
Keith
Re: Loctite 680
all the info you need can be found here
https://tds.us.henkel.com/NA/UT/HNAUTTD ... 680-EN.pdf
For Cleanup
1.Cured product can be removed with a combination of soaking in a Loctite solvent and mechanical abrasion such as a wire brush
Re: Loctite 680
but will it damage the bond? need to be careful of thatFender wrote:I read in another forum that MEK will remove loctite.
Re: Loctite 680
Thanks Finger nail polish remover worked on the uncured and a paint scraper worked on the harder parts. It was not fully set up.
Re: Loctite 680
On another board I participate on (out of the UK) there have recently been reports of failures of otherwise perfectly prepared Loctite joints and the suspected culprit is counterfeit Loctitie.
GWRdriver
Nashville TN
Nashville TN
Re: Loctite 680
Don't know what is worse - fire hazard from ACETONE or breathing hazard from MEK.
I used to use carbon tetrachloride for this purpose....but then maybe that explains a lot of things....
Acetone (nail polish removes is acetone) will remove...just be careful where you apply it...
get it into the joint and you have problems.
Best to scrape it off.
Re: Loctite 680
I agree about avoiding solvents. If it is uncured, perhaps apply some primer or accelerant to cure, then scrape the excess off mechanically. That way there is no danger to the joint.
