Little Engines Air Pumps
Re: Little Engines Air Pumps
It sounds like an up-to-date set of plans needs to be made in 3D, incorporating all the changes and showing perspective cutaway views for clarification.
If I ever bought a set of castings and prints I'd probably do that for myself along the way of building it anyway.
Thanks for the answer on the regulation. So basically, the higher steam pressure you feed the pump the higher air pressure you'll have. Just leave the steam feed valve open.
Anyone had any problems with water condensing when it is not operating and then causing it to lock up? I assume if it's exercised often enough it won't collect too much condensation. Maybe an automatic cylinder cock that responds to water hammer pressure (like SuperScale's) would do the trick.
Cheers,
-Mike
Cheers,
-Mike
Mike,
I think once you get going the use of the brakes keep the pump moving enough. We don't have any problem with our pump on #4 stopping due to condensation once we get it going unless we stop a long time and don't use it. We run more in the winter than summer due to fire hazards so it sees a lot of temp differences! It slows down when it gets to about 90 lbs but keeps going when needed.
Tom C.
Tom C.
tom_at_srclry_com
A student of the Southend RGS!
I have this problem with the keim pump i have, i plan on adding a safety valve that will release the pressure at ~ 60 psi (my train line is normally set to 40 psi, 50 if i am running heavy)Harlock wrote:Anyone had any problems with water condensing when it is not operating and then causing it to lock up? I assume if it's exercised often enough it won't collect too much condensation. Maybe an automatic cylinder cock that responds to water hammer pressure (like SuperScale's) would do the trick.
Cheers,
-Mike
this will keep the pump running and hot.
Can anyone post a photo of the umbrella valve?
I'm currently talking with Vernay right now but I accidentally called it the wrong part, so I have to start over on the dialogue.
Thanks,
Mike
Thanks,
Mike
On the BJWCRR #2 we had ball valves on the air side of the pump which we would open to allow the pump to pump against atmospheric pressure while it warmed up. When you closed them, you'd leave them cracked a little so just a wisp was coming out. The other trick was to keep the pump cycling, even if only every 20-30 seconds. On a normal day none of this was needed, you used enough air things worked fine.cbrew wrote:I have this problem with the keim pump i have, i plan on adding a safety valve that will release the pressure at ~ 60 psi (my train line is normally set to 40 psi, 50 if i am running heavy)Harlock wrote:Anyone had any problems with water condensing when it is not operating and then causing it to lock up? I assume if it's exercised often enough it won't collect too much condensation. Maybe an automatic cylinder cock that responds to water hammer pressure (like SuperScale's) would do the trick.
Cheers,
-Mike
On the steam outlet side we had another valve that would route the exhaust onto the ground while warming up, and then up the stack once you had the hydrostat set and things were warm. It kept us from blowing quite as much steam cylinder oil over the passengers while dialing in the drip rate.
John Brock
So....
Do we start a dedicated thread to build them?
If so I will drag out my castings to jump in.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
I will also try my hand at a build thread also.
Just need to find a line on these umbrella valves...
They are the major source for them but they want u to by them by the thousands! Ask for samples and u can get maybe 20 or so. We got some spares from our pump builder but they r in Michigan and I am not so can't post pics.Mike Walsh wrote:Can anyone post a photo of the umbrella valve? I'm currently talking with Vernay right now but I accidentally called it the wrong part, so I have to start over on the dialogue.
Thanks, Mike
Tom C.
tom_at_srclry_com
Mike-I'm currently talking with Vernay right now but I accidentally called it the wrong part, so I have to start over on the dialogue.
Thanks,
Mike
I received 10 samples from Vernay in September. Here is what is on the package:
Part No: V027910500
Design/Size: VA3405
They also included an engineering drawing with the title "Umbrella Check Valve" and "Part No. VA3405".
-Larry
Do you recall how you picked up this sample package? Have a contact by chance?
I need to figure out how I'll get a bunch. If this goes well, may need to equip up to 10 compressors, if not more...
Curious Question.
Are the umbrella valves made of a plastic?
Charlie Pipes
Current Projects:
Current Projects:
NitrileAre the umbrella valves made of a plastic?
-Larry
