Page 11 of 34
Re: A champion is born.
Posted: Fri Aug 29, 2014 10:17 am
by Highiron
Great Job Professor Paulie!!
Posted: Fri Aug 29, 2014 10:30 am
by Andypullen
That is awesome!
Andy
Posted: Fri Aug 29, 2014 12:53 pm
by Highiron
Paul
It sounds really square...great!
I have the Trailing Truck done just have to pack it in the case and it will ship to you Tuesday
came out good here are the pictures
Posted: Fri Aug 29, 2014 1:27 pm
by SilverSanJuan
Music to the ears, Paul. Runs and looks beautiful.
Todd
Posted: Tue Sep 02, 2014 7:24 am
by kapullen
Paulie,
You do such nice work. You, Pam, and Mike, are an inspiration to many of us out here in la la land.
Kap
Posted: Wed Sep 10, 2014 4:54 pm
by pkeiser
Power pack that goes in the tender. It lifts out easily for maintenance.
This is a steel drop in container. Holds an APC heavy Battery and a Thomas air compressor all under a hinged top.
The top swings back on a hinge. On top panel are the fuses ,a charger for the battery , a knife switch to lift ground, relay for starting the compressor, and the cord to plug into 110V. outlet to charge battery.
Posted: Sat Oct 25, 2014 4:14 pm
by pkeiser
Finally back from California where Mike and I picked up the Hudson from Jack's shop. Nick Edward's meet just over also and we all had a great time! Thanks to Nick and Lynn and Bob Hornsby.
Back to work on important stuff. Installed boiler. All buttoned up and happy. It ain't coming off for a long time, I hope. Besides, by that time I'll be eating chocolate cake with Jesus and I'll have a real machine shop!
Posted: Sat Oct 25, 2014 4:52 pm
by boomerralph
She is looking great Paulie!
Posted: Sun Oct 26, 2014 11:45 am
by Bill Wilkins
Very nice, something to be most proud of. I also like the cab picture. Looks as if you could just crawl in and get her moving. Oh, the experiences the engineers had with the full size ones.
Congratulations...
Posted: Sun Nov 02, 2014 6:41 pm
by pkeiser
Rear end of things. I have found that anything under the cab floor that is not metal.... MELTS !!!!. That "wall" below the firebox door is a heat shield. Double walled with a 1/2" air gap between. The Hudson was my first and I had DOT air lines and Clippard air regulators and all failed . The heat shield solved all that. Coal gets REAL HOT !!!
Posted: Sun Nov 02, 2014 9:55 pm
by GS14403
Hello Paul,
I like the look of the compressor you are using. Do you sell them direct or should we order them from Thomas. Either way do you have the model number of the compressor you are using and does it have an adjustable pressure regulator. I find about 30 PSI is more than adequate for my engine and tender brakes but will be needing more volume as I start adding air brake cylinders to my cars, replacing the vacuum pods used previously.
That new Northern is coming along great and looking awesome, the more of these out there the merrier.
Donald
Posted: Mon Nov 03, 2014 9:26 am
by pkeiser
Donald, please contact Mike at with Little Engines. He has all that information.
Paul
