Need help with tooling taper
heapes
Post by heapes » Fri Apr 25, 2014 10:20 pm
I have an old milling machine that I recently purchased and I am trying to verify the tooling taper. The sales literature lists the vertical head spindle as being "standard milling machine tapered spindle #30". Another place lists it as "#30NMM taper". So, if I were to leave the 1950's and open the ENCO website, what name would I search to get this tooling? Thanks for your help. Stephen.
Ps. I got a bunch of brown & sharpe collets with the machine but the guy had 10 different machines and a hoard of tooling. --ie I don't know the collets go with this mill.
Steamin
Re: Need help with tooling taper
Post by Steamin » Fri Apr 25, 2014 10:56 pm
According to my 1950's Machinery's Handbook; National Machine Tool Builders (NMTB) #30 might be what you are looking for.
Fred_V
Post by Fred_V » Sat Apr 26, 2014 7:47 am
It could be anything. I have an old Gorton that uses Standard #30. What machine is yours? You may have to measure the taper and then go to the charts.
Fred V
Pensacola, Fl.
heapes
Post by heapes » Sat Apr 26, 2014 7:57 am
1950's model by Heald machine works. It's a horizontal machine with a heald vertical head. A rare bird as I understand. Thanks for any help. I will start measuring.
Russ Hanscom
Post by Russ Hanscom » Sat Apr 26, 2014 9:31 am
Might repost under Milling Machines, in the lower section of the index.
The 30 Taper should have a standard taper, what can vary is the pilot where the draw bar screws in, and the driving flange. Some of the recent versions are pilotless, and some have modified flanges for auto tool changers on CNC machines. For an older mill, the handbook details should be correct. NMTB and NMM are used somewhat interchangeably. I use to buy 30 taper holders on Ebay for my Fray mill and never got one that did not work.
Fred_V
Post by Fred_V » Sat Apr 26, 2014 5:12 pm
Russ Hanscom wrote:Might repost under Milling Machines, in the lower section of the index.
Russ, are the NMTB/NMM also basicly the same as the std. #30? I've never quite understood the nomenclature.
Fred V
Pensacola, Fl.
Russ Hanscom
Post by Russ Hanscom » Sat Apr 26, 2014 6:20 pm
As far as I know, yes. The taper is common to all. The letters before or after the "30" may depend on the source publishing it. As noted, some of the later versions for CNC have no pilot as they may not use a draw bar, and the flange is modified for tool changers.
