Question regarding eccentric throw
seal killer
Post by seal killer »
All--
I want to build something other than oscillators. I am stumped on the relationship of eccentric throw to crankshaft throw. Is there a simple explanation, or at least one I may be able to understand?
Thanks.
--Bill
You are what you write.
Curtis_F
Re: Question regarding eccentric throw
Post by Curtis_F »
Bill,
I have the feeling I'm misinterpreting the question, but ya' gotta start somewhere:
Crank Shaft Throw is 1/2 the stroke of the engine. If the throw of the crank is 1" then the piston will travel 2" for ever rotation of the Crank Shaft.
Eccentric Throw is directly related to travel of the Valve in the steam chest. (Not accounting for angularity offsets, Rocker Shafts, etc.) If the Eccentric Throw is 1" then the Valve travels 1" for every rotation of the Crank Shaft.
Generally Eccentric Throw is a small portion of the Crank Shaft Throw as it only has to move to cover and un-cover steam ports. An engine with 20" Stroke (2 X Crankshaft Throw) may only have 3.5" of Valve Travel/Eccentric Throw.
Cheers,
Curtis F.
[edit]Thank you joneg for pointing out my error in the description of the Crank Throw.[/edit]
25+ Years of SolidWorks experience...now I feel old.
"You can lead a horse to water, but you can't make him drink."
"Winning an argument on the internet is like winning the Special Olympics."
www.facebook.com/HillcrestShops
seal killer
Curtis--
Generally Eccentric Throw is a small portion of the Crank Shaft Throw as it only has to move to cover and un-cover steam ports. An engine with 20" Stroke/Crankshaft Throw may only have 3.5" of Valve Travel/Eccentric Throw.
That answers my question PERFECTLY! I suspected that eccentric throw only needed to be enough to operate the valve, but I had never read anything that actually said that.
Thanks!
--Bill
joneg
Post by joneg »
the stroke will be twice the throw
joneg wrote:the stroke will be twice the throw
Correct. A 1" throw crank yields 2" of movement, as the offset of the crank is determined between the centerlines of the mains and throw.
seal killer wrote:Curtis--
Thanks!
--Bill
True, and the same principle applies with an eccentric as it does with a crank. If the offset of an eccentric is ¼", it will yield ½" of movement.
mklotz
Post by mklotz »
Animations make the operation of various engines easier to understand. There are some good ones here...
http://www.animatedengines.com/
The "Steam Locomotive" animation is particularly good since it shows the interplay between the classic, eccentric-driven slide valve and the double-acting piston driving the flywheel through a connecting rod.
Also, the "Low Differential Stirling" animation helps one to understand what's going on in a heat engine, a form not familiar to most people outside of the engineering community.
Regards, Marv
Home Shop Freeware
Curtis_F
Post by Curtis_F »
Thank you for pointing out my error about the Crank Throw. I've gone back and fixed my description.
However, contrary to that logic, "Eccentric Throw" is the Eccentric Offset x 2. An eccentric with 1/4" offset gives 1/2" of Throw. If there are no mitigating factors such as angular offset, use of a Link or Expansion Link, or unequal length arms on a Rocker Shaft, the Eccentric Throw will equal the Valve Travel.
So a Crank, or Wheels with Crank Pins, with 1" throw is actually 2" of travel of the piston, but an Eccentric with 1" throw is actually 1" of travel of the valve. The same is said for Eccentric Cranks on Walschaerts valve gear where the diameter, not the radius, of the circle the Eccentric Pin is described as the "Eccentric Throw"
Cheers,
Curtis F.
seal killer
Marv--
Thank you for the link!
--Bill
