slop in drive box to frame
how much "slop" can you have in your drive box to frame? by that I mean side to side, up an down , I have .020 on side to side, and .010 up and down. I get some bind ,never any were the drive wheel's stay up when I run a low spot.
Re: slop in drive box to frame
Is this an engine you are building? What do you mean by "up and down"? Side to side you should be be able to move the driver a total of 1/16". This allows the drivers to offset when going around a curve. Fore/aft clearance should be around .006" to prevent the rods from binding when one axle goes over a bump or dip.
Fred V
Pensacola, Fl.
Pensacola, Fl.
I do not have any rod bind. By up and down I mean the drive box/wheel set, as you point out ,moving back and forth. This is on a 4-8-4 in 3/4 " scale built from a Little Engine set of casting's.
