I just completed a homebrew shaft encoder project on my Sherline lathe. It has index and phase A. Phase A has 16 divisions because I am using Linux CNC to track the pulses in software and that limits the possible resolution. What I read indicates that this is about the max resolution for LinuxCNC or Mach to keep up with unless you add hardware support.
inexpensive low resolution shaft encoder
Re: inexpensive low resolution shaft encoder
what are you using for a encoder??
I am using two photo emitter/detector pairs and a shaft encoder strip I designed in CAD and printed on my printer.
