G-Code Love
ctwo
G-Code Love
Post by ctwo » Tue Jan 26, 2016 3:02 pm
I was preparing for Valentines day (although I'm unsure if my machine will be ready in time). I created this code block that can be run on a 1" round bar stock stood vertical in the mill, with center at 0,0. It uses about 1/2" of stock, which can then be parted off in the lathe. There is about 0.4 x 0.2 flat for engraving if desired.
The formula for the outlines:
x=16sin^3(t) (Edit: this is supposed to be the value of sin cubed.)
y=12cos(t)-5cos(2t)-2cos(3t)-cos(4t)
where t is an incrementing angle (0 to 2pi). I am incrementing in 0.1 radians per code line to generate each curve. Each curve is reduced in "diameter" by a 2nd order function as Z is raised 0.050
Note that none of the tool or machine setup is included and I have only run the program in a simulator. I imagine a 1/8" ball end mill would make a usable shape, but I expect there would be stepping (kerfing?) lines. If anyone runs this, let me know if it needs any tweaks.
g-code-love.txt
(70.69 KiB) Downloaded 60 times
Re: G-Code Love
Post by SteveM » Wed Jan 27, 2016 9:30 am
In math, what does:
x=16sin^3(t)
mean?
Looks like you are raising something to a power, but you can't raise SIN to a power, as it is only a function not a value.
Rick
Re: G-Code Love
Post by Rick » Wed Jan 27, 2016 12:33 pm
to me it must be a typo, I would think the equation isn't raising the sin to a power its simply 16 times the sin of the value of 3 times (t), where t is the incrementing angle
or 16(sin(3t))
Rick
ctwo
Re: G-Code Love
Post by ctwo » Wed Jan 27, 2016 12:35 pm
Steve, it is the value of sin(t) cubed. I did not want to confuse raising t to the third power.
x = 16 * (sin(t))^3
BTW, I have to replace the g-code txt file because it will make the initial outline at full depth and break the cutter. I think I can step the outline down in 0.050" increments from the top, and then step back up and inward for each subsequent layer.
ctwo
Re: G-Code Love
Post by ctwo » Sat Feb 06, 2016 4:29 pm
Here is an update. Same file as first one for the boss, pocket attached here. I just ran it a couple times and raised the knee...
heart-pocket-01.txt
(48.73 KiB) Downloaded 51 times
RET
Re: G-Code Love
Post by RET » Sun Feb 07, 2016 10:29 am
Hi ctwo,
Very nice. I'm impressed.
Richard Trounce.
ctwo
Re: G-Code Love
Post by ctwo » Wed Nov 29, 2017 8:40 pm
I am working on another. Here's the rub - my software no longer works on the recent Win10 Creators update. Well, I'd be learning all over again anyway... also, I want to cut the outside shape as well, so working on a good way to hold the work piece and then get rid of the holding stock... AND I want a better hinge.
ctwo
Re: G-Code Love
Post by ctwo » Thu Nov 30, 2017 4:05 pm
OK, here is an idea:
The piece will be 1" finish height (0.155" thick lid and 0.845" body) and 1.625" tall and wide. I will use oversize 2" round stock faced to 1.2" long, then flats on opposite sides, 0.100 deep. That will give me a flat surface to grip in the vise.
I will mill the body OD and pocket first, then I can flip it over and mill the lid OD and engrave, leaving the extra holding stock closer to the lid. I've determined that the shape will grip fine in my 3-jaw chuck, so I will part the lid off through that stock and have about 0.050" to face off each piece. The body should be strong enough since there will be 0.155" solid at the bottom of the body. It will be beautiful!
I also think that I will counter bore the lid to use a small cap screw for the hinge, and maybe even make a plug to hide the hole..
