Ball Screw Pitch
ed92254
Ball Screw Pitch
Post by ed92254 » Thu Nov 16, 2017 11:05 am
Setting up a lathe for CNC and was wondering if ball screw pitch can be different between the Z axis (5MM) and X axis (4MM). Had to get a smaller ball screw for my X to physically make it fit and found out it was 4MM pitch.
ctwo
Re: Ball Screw Pitch
Post by ctwo » Thu Nov 16, 2017 11:10 am
I believe this would be addressed in your controller software - which one are you using?.
ed92254
Post by ed92254 » Thu Nov 16, 2017 11:16 am
Mach 3
Dave_C
Post by Dave_C » Fri Nov 17, 2017 1:16 pm
Yes, Mach 3 will let you set up each axis with different leads or different motors. It is calculated in the turns per inch entry if your are using imperial setups. If you are setting up a metric setup it wants distance of travel per one turn of the motor.
So a .200" lead would be 5 tuns per inch and so on. You can use metric ball screws and still set up your machine as "inches" but you'll have to do some extra math.
Dave C.
Post by SteveHGraham » Fri Nov 17, 2017 2:01 pm
Wow. A CNC question I could have answered.
ed92254
Post by ed92254 » Fri Nov 17, 2017 5:02 pm
Thanks for the help guys its been a fun build so far and sorry if I ask some scary questions?? lol
dash9
Post by dash9 » Mon Nov 20, 2017 9:13 am
Sling Mach 3 out get the Centroid Acorn.
http://www.centroidcnc.com/centroid_diy ... oller.html
Dave_C
Post by Dave_C » Mon Nov 20, 2017 4:38 pm
I'd second that, even though I am still running a Mach 3 lathe conversion. Centroid is Funac compatible and runs a full set of G-codes while Mach 3 runs a partial set and is not compatible with anything else, as far as I'm aware. You will need a spindle encoder, a real one and not just the indexing type like mach uses, if you want to thread or do rigid tapping with the Acron/Centroid setup.
I'm in the process of reading the entire manual right now for the Centroid lathe and mill software. It is written very well, more like the way I understand tech manuals.
Dave C.
Post by Bill Shields » Mon Nov 20, 2017 9:05 pm
actually you want an encoder WITH a zero pulse index point so that you can reliably find home every time.
Dave_C
Post by Dave_C » Mon Nov 20, 2017 10:02 pm
Ok, My poor explanation! Mach 3 uses a single slot spindle index and nothing else. So basically you make a disc with one slot in it, use an optical reader to read the slot or you can use one of those other type single pulse per rev encoders like a photo tac.
Mach 3 can't read a real 2000 line encoder for spindle positioning. Mach 3 also can't use CSS and FPR at the same time. (constant surface speed and Feed per Rev) One or the other but not both!
So no rigid tapping!
Dave C.
ctwo
Post by ctwo » Tue Nov 21, 2017 6:09 am
I'd have to spring for the Centroid Pro CNC. Looks like an interesting solution.
Marty_Escarcega
Site Admin
Post by Marty_Escarcega » Wed Dec 13, 2017 7:39 pm
ctwo wrote:I'd have to spring for the Centroid Pro CNC. Looks like an interesting solution.
You WON'T be dissappointed!
Marty
