Having decided to upgrade my sherline to cnc, want to try and understand G-Code and write a few small programs. Can someone point me towards a site that explains it. I have a G-Code viewer, just don't understand how they code in one line to mill a complete circle, plus a few other hunderd items I don't understand at present.
Seems this is the best site around for home cnc so thanks all who can help out.
Jim
Abbotsford, BC
Understanding G-Code
Re: Understanding G-Code
Hi Jim;
I'm not an expert but I have done some G-code programming.
I'll list some G-code and explane what they mean.
G00 X0 Y0 Z2
Okay, G00 simply means go to where ever X0 Y0 Z2 is and go at full speed. All three axis with move at the same time.
G01 Z-.1 F5
G01 is a controlled speed movement.
Keep in mind Z0 is usually the surface of the workpiece in reference to the tool. Z-.1 means the tools plunges into the workpiece .100" deep at a feed rate of 5" per minute. Your machine will continue feeding a 5" per minute intill you change it some where else in the program.
G01 X1 Y0
The tool (at -.1) with now advance right from X0 Y0 to X1 Y0 at a feed rate of 5" per minute. The Y axis did not move.
G01 Y-1
Tool moves forward 1" at 5" per minute. Now the tool is at
X1 Y-1 Z-.1
G02 X2 Y-1 R.5
Move tool to right but swing a .5 radius to get to X2 Y-1
G02 is a clockwise (i think) movement.
G03 is a counterclockwise movement.
There are also "I" and "J" commands for radius moves but so far have no experience with them.
Jim
G00 X0 Y0 Z2
G01 Z-.1 F5
G01 X1 Y0
G01 Y-1
X1 Y-1 Z-.1
G02 X2 Y-1 R.5
Jim
www.outbackmachineshop.com
Thanks Jim
Its a place for me to start. When I find time will keep searching the net for something that helps out learning it. The software that I have will write g-code just have no idea what it all means. You might not be an expert but what you gave me helps alot.
Thanks again
Jim
Abbotsford, BC
Thanks again
Jim
Abbotsford, BC
Jim:
I would like to learn the software that writes G code. Thinking about taking a college course this fall. I'm also in the market for CNC mill.
I wrote G-code for my home built CNC machines. Good way to learn, writing the G-code then watching the results.
Jim
Jim
I , J , K
HI ,
I USE IN THIS WAY I J K LETTER IN CIRCLE/ARC G CODE PROGRAM
XY AXIS
_SIMPLE WAY
THE CENTRE OF THE COMPLETE CICLE IS X0 Y0 (RELATIVE ZERO G54 )
_1st EVENT WORKING INSIDE CIRCLE
G00 X0 Y0
G01 Z-........
G01 X10 Y0 F1 (MOVE FROM X0 TO X10 Y0 ISN`T IMPORTANT HERE)
G02 I-10 ( THE TOOL PATH START AT X10 LIKE 3:00AM RUN FOR
360 DEGREES CW AND STOP AT X10 )
_2nd EVENT WORKING OUTSIDE CIRCLE
G00 X20 Y0
G01 Z-........
G01 X10 Y0 F1 (MOVE FROM X20 TO X10 Y0 ISN`T IMPORTANT HERE)
_COMPLEX WAY
THE CENTRE OF THE ARC IS X0 Y0 (RELATIVE ZERO G54 )
_ EVENT WORKING INSIDE/OUTSIDE ARC
G00 X1 Y3
G01 Z-........
G02 X1 Y-3 I-1 J-3 ( THE TOOL PATH START AT X1 Y3 THEN STOP
AT X1 Y-3 "THE CENTER IS X0 Y0 RELATIVE G54"
_NOTE- EVERY FINAL POINT OF THE ARC CAN BE USED
BUT THE I J MUST BE THE SAME NUMBER AT START POINT
WITH SIGN CHANGED
IF THE X/Y AT START WAS +/- THE I/J MUST -/+
WHEN THE CIRCLE/ARC IS ON XZ AXIS OR YZ AXIS
K LETTER MUST BE USED
CIAO FROM ITALY
DOMENICO
XY AXIS
_SIMPLE WAY
G00 X0 Y0
G01 Z-........
G00 X20 Y0
G01 Z-........
_COMPLEX WAY
G00 X1 Y3
G01 Z-........
WITH SIGN CHANGED
CIAO FROM ITALY
DOMENICO
You could do worse than to read the intro to CNC/G code that is on the Sherline web site:
http://www.sherline.com/CNCinstructions.htm
cheers,
Michael
cheers,
Michael
I would buy a book(s), or your library may have one. I would recommend CNC PROGRAMMING, PRINCIPLES AND APPLICATIONS by Mike Mattson. ISBN 0-7668-1888-8.
Great book for teaching G-Code. I refer to it whenever I'm writing a program. Some other G-Code books are just lists of the various codes with examples. This one is a teaching text. Probably $60. Amazon will have it.
