The OP posed the original questions:
Quote:
Does the fourth or fifth axis have reference point?
Does the rotary axis need go to reference point when turn on the cnc machine?
and somehow got side tracked into tool changers.
Quote:
Bruce_Mowbray wrote:
Correct me if I'm wrong. I thought an absolute encoder knows where its own zero is (within one revolution). The machine must be brought home (to a limit switch type device) to within one encoder revolution of the machine home, then the encoder takes over to find it's own home and the machine control sets this to the axis home position. The Haas rotary axis I used worked the same. When I turned it on, it would look for it's home by rotating slowly. Whenever I powered up the rotary unit, it moved close to the home zero on the axis, the unit would advance slowly and stop when the axis was at it's true "home zero point" and the readout would register at 0.000. I didn't have a choice in this matter. The unit went through an automatic start up procedure before I could use it.
"EXACTLY". Otherwise, how does it know where it is. Once it has been sent to a HOME position, then you can lie to it and tell it a new zero position in your G54 work shift.
Correct! If you want to have repeatability the next time you turn your machine on, it must be 'homed'. I usually do one-offs and don't bother with homing my rotary.
Dean
