Just finished a pair (Rh and LH) trim pieces for a buddy of mine that runs a Hot Rod Shop. The originals were pitted to the point they weren't repairable and replacements can't be found. Machined out of alum, 3D profile was machined with a 1/8 ball endmill with a .005 step over.
Post on the back will be threaded 10-32. Lots of fun and i even get paid for them
trim part
trim part
Rick
“We make a living by what we get, but we make a life by what we give." Sir Winston Leonard Spencer Churchill (1874-1965)
"Peace is that brief glorious moment in history when everybody stands around reloading". Unknown
Murphy's Law: " If it can go wrong it will"
O-Tool's Corollary: "Murphy was entirely too optimistic"
- Site Admin
Re: trim part
Nice work Rick. Are the posts integral to the part? If so, that looks like a lot of chips came off of it!
Marty
Marty
Re: trim part
Those look great I sure hope those posts are threaded in...
Re: trim part
Thanks guys
The post are integral to the part, the main body is only .200 thick and the grooves are .075 deep so there wasn't anything left to be able to drill and tap a hole. The original part was die cast, and I needed to try to stay as close to it as possibe. I think it goes on a 60's Mercury Comet. I used the cnc to orbit the post then used the saw and manual mill to remove the rest of the material. I had to do it in three steps due to having to toe clamp the part to the table since it couldnt be held in a vice as the outer walls are tapered and have a large radius. Thought about doing the post first but then the post would be the only thing I could use to hold the part for the 3D machining and that scared me even more. Fun stuff. Had to say my main concern was a having lapse of concentration and accdently wacking off one of the post
Rick
