Motor/Driver Compatibility
I'm just thinking of setting up a single axis CNC rotary table, 8". Mostly just to cut gears. I was considering a worm gear drive with driving the worm direct from a stepper, something like a 4" worm wheel just behind the handle.
I'm wondering for this application, if I should be looking for a larger motor?
And if this motor and driver would work together? I might want to use it for something else if they are compatible.
http://www.ebay.com/itm/CNC-Router-Nema ... 3384a41f5a
http://www.ebay.com/itm/CNC-Router-Sing ... 7673035%26
Re: Motor/Driver Compatibility
I went with something else just to make it, easier?
http://www.ebay.com/itm/Free-to-USA-CA- ... OC:US:3160
- Site Admin
Here is a self contained Rotary Table Indexer build on CNCZONE:
http://www.cnczone.com/forums/open_sour ... er-62.html
Lots to read there, Marty.
I read that a G251 driver would be ideal, but the one I ordered is also good, so that is comforting. I think there is somewhat a deficiency on the motor, though not yet sure.
Here is an interesting bit: "...if the MotorSteps x DriverSteps x WormRatio is greater than 65535 then it won't work."
Now I had not considered it and don't fully understand the issue.
200 * 128 * 90 = 2.3 million?
Just a note to myself, the 65535 limit is due to 16-bit variable in the controller provided by the designer of that build.
baby stepper motors in. These might be used for a telescope drive, that was the concept anyway, but the stepper might not be a good solution due to the clicks...
These are 1/4 steps, quick and dirty just to see it spin. My first motor...
http://www.youtube.com/watch?v=eER-duWn1DU
I got the larger motor in. Longer than I was expecting, but it should work.
What the heck, I was still having fun with the babies...
http://www.youtube.com/watch?v=kX_DwDbvIlE
- Site Admin
ctwo wrote:I got the larger motor in. Longer than I was expecting, but it should work.
Cute, I wanted to see the plastic clothes pin go flying! What are you controlling them with?
It is an AVR 328p chip (Arduino) and A4988 based driver modules.
I programmed a simple pulse cycle to increment at various rates to a max of ~500 kHz. (and yeah, the clip did fly off a few times, amazing that they stay on as well as they do...)
I think in the thread you referenced above, someone from your team ported the PIC code there to a newer chip. So now I'm contemplating just using that solution for the controller vs making my own. I can program either using AVR studio or the Arduino IDE (which I'm more familiar with) or using a PICKit2 with MPLAB, but I'm not a heavy programmer.
I was also inspired by the work of Chuck Fellows and am now considering whether I want to convert my manual Rotary Table or just make my own dividing head. There are benefits and drawbacks either way.
