ok, let me start by saying I'm not a computer guy but I can find myself around 2D Mastercam to cut 2D parts... I picked up a tmc1000 benchtop mill, then I picked up an older dell comuter, then a pci card to hook up the mill controller to... I have Mastercam... now I need some sort of user interface software so I can reference, set zeros and jog the mill... In the stuff I have the tmc1000 I found a floppy by Microsolutions labeled Matchpoint-PC. Is this the software I need for the user interface? If so, how do I get it to usable media since computers don't have floppy drives anymore?
Might it be easier to find a different user interface software? Are there any out there for cheap or free?
Thanks in advance guys- this is a project I've been working on, off and on, for a year or two...
TMC1000 mill user interface software?
Re: TMC1000 mill user interface software?
OK, just researched matchpoint pc.. if I am correct, this floppy is ment to be downloaded on an ibm computer so it can read and write floppies in a pc format... so I'm pretty sure this is not what I need regarding a user interface for the mill.... I also found Spectra cam master discs but when I put them in, my computer can not read the files.... not sure what is on these discs...
Can't help with your software but USB floppy drives are cheap and readily available. Some just need to be plugged into a USB port and some have separate power supplies.
Don Young
Hi ray299,
I recently acquired a TMC1000 and a box full of discs and manuals, spare parts etc.
If you need some of the original software, that you think you may be missing, let me know and I will go dive in the box to see what I have.
