g-code types
Re: g-code types
Bill,
There's quite a bit more in common then 4 commands. Aside from the far out whacky and or out dated controls..... most are based on fanuc. The drill cycles are the same, the milling cycles are the same.
Who uses a mirror code anymore? Cam software eliminates a ton of codes.
If you are using cam software, what codes would you need beyond let's say..
G0, 1, 2, 3, 81, 83, ..... and perhaps a couple more ?
G92? Haven't typed that on in since the mid 90s.
Re: g-code types
G92 can be a threading cycle or it can be a max turning spindle speed clamp., depending on the FANUC code setting....or if you are running a MITS WIRE EDM, G92 is used every time you thread / start a new burn contour -> so it is used a LOT with modern machines.
We also still use mirror codes all the time, even with CAM systems. With many machines it allows us to write IDENTICAL CODE for Main or Sub spindle with only the change of a single line in the channel. Or, if you are pinch turning where you have identical paths / tools in opposite sides of a turning part, the MIRROR command makes it easy to slave two turrets together and ensure that they both do exactly what you want at the same time.
No, I don't do work for hobby machines, since their users typically cannot afford the software we sell
I write for the major machine manufacturers: Star, Citizen, Mori-Seiki, DMG, Mazak, Tsugami, Matsuura, Haas, Fidia, Tornos, Willemin-Macodel, Index, Traub, Hardinge, Nakamura-Tome, Hermele and about 100 others..
keeps me busy....
keeps me busy....
Re: g-code types
Good Morning Bill,Bill Shields wrote:G92 can be a threading cycle or it can be a max turning spindle speed clamp., depending on the FANUC code setting....or if you are running a MITS WIRE EDM, G92 is used every time you thread / start a new burn contour -> so it is used a LOT with modern machines.
keeps me busy....
Well if you ever decide to write a Programmers Hand
Book you will have alot of buyer's
Ken.
One must remember.
Ken.
Ken.
Re: g-code types
I have all the buyers I can handle right now, thanks..
www.partmaker.com
I am one of the guys that writes the post processors for all these crazy machines.
http://www.partmaker.com/postprocessing/index.asp
Handbooks really aren't the way to go - you need manuals for each machine / controller combination...and the time to read / translate / understand them...then figure out why two seemingly identical machines need different code (100's of different parameter settings makes our life interesting).
never a dull minute..
www.partmaker.com
Re: g-code types
I used to use the G92 when working with castings that had references to multiple cast surfaces. I would program a probe to come up and touch off of the referenced cast surface, enter the G92, have that portion of the program use the probed reference as the current offset, do the machining, then go back to g90 or g91 to continue on with the regular machining based on the original work piece zero point.
Just another tool in the CNC toolbox.
Bruce Mowbray
Springville & Southern RR
Re: g-code types
ctwo,
I stumbled on this and thought I would
throw it your way for your perusal.
CNC Code SHOOTER HELP
http://www.cnccodeshooter.com/CodeShooterHelp.pdf
CNC Code SHOOTER FREE TRIAL
http://cnccodeshooter.com/
Ken.
Ken.
One must remember.
Ken.
Ken.
Re: g-code types
there is a lot there for $20.00
for someone just getting started in programming, it is hard to find major fault with the offering....and $19.95 is only a couple of gallons of gas or a trip to McD's for dinner
get some inexpensive software that will output basic DXF files and you can have a lot of fun.
The only item that I would point out is that not all machines program IJK for arc center definition exclusively in INCREMENTAL from the arc start point.
Yes, that is the FANUC way of doing things, but there are many controls out there that program arc center IJK in ABSOLUTE if you are programming XYZ in ABSOLUTE and INCREMENTAL if you are programming XYZ in INCREMENTAL. I personally own one (giggle)...
Maybe his software has a SWITCH to allow you to set this, but the help file does not specifically say one way or another.
Re: g-code types
ctwo
This site is very interesting and informative.
Check out there G-Code Chart
http://www.cnc-joe.com/index.html
ken.
ken.
One must remember.
Ken.
Ken.
