Can't Buy Sensor for Stirling-Steel CNC Conversion
Post by SteveHGraham » Wed May 21, 2014 7:45 pm
I have yet another problem with my CNC mini lathe conversion. The specified spindle sensor is from Euro-Spec (IS12-Y4-N-OC-DC). They will not sell it to me because they have a $50 minimum. Is there some other sensor I can use? I don't even know what the numbers mean.
hammermill
Re: Can't Buy Sensor for Stirling-Steel CNC Conversion
Post by hammermill » Wed May 21, 2014 9:35 pm
If you are after a hall effect speed sensor. They are 20.00 on eBay
Post by SteveHGraham » Wed May 21, 2014 10:07 pm
Here is a link. I can't find anything like it at Mouser or Digikey.
http://store.eurospecdirect.com/is12y4nocdc.html
Bob D.
Post by Bob D. » Wed May 21, 2014 10:18 pm
It's a standard prox switch. Just match up the specs given in the link you provided and you will be ok.
Bob
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
ken572
Post by ken572 » Thu May 22, 2014 12:09 am
One must remember.
Ken.
Post by SteveHGraham » Thu May 22, 2014 10:03 am
I don't suppose anyone would be willing to decipher the specs? I tried it on Mouser and Digikey, and they didn't have anything. Some of the terms are obvious, but others...
Post by SteveHGraham » Thu May 22, 2014 11:31 am
Ron Steele, the dude who sells the plans, is going to sell me a sensor. If I can figure out the specs, I will post them for future Googlers.
rrnut-2
Post by rrnut-2 » Thu May 22, 2014 11:56 am
IS12-Y4-N-OC-DC Inductive Sensor M12, not embeddable, 4mm range, NPN, NO+NC, 10-30VDC, 4 wire cable, LED
M12 Thread - Barrel Size
Sensing head must not be embedded in metal or else it won't work
Range: 0-4mm
NPN: to switch "on" load, it closes with -24vdc
NO+NC: Black wire = Normally open, White Wire = Normally closed
Operating Voltage Range: 10-30 vdc
4 wire cable: Brown = +24vdc, Blue = -24vdc, Black = NC, White = NO
LED to show when it switches
Jim B
Bob D.
Post by Bob D. » Thu May 22, 2014 12:06 pm
The prox you linked.
4 mm range, target must be within 4 mm of the sensor face
10-30vdc range of operating voltage for the sensor
4 wire, NO NC. Essentially two "contacts" one normally open, one normally closed.
LED. Indicator light shows target detection
NPN. Sinking input. The other flavor is PNP sourcing output
M12. mm diameter of sensor.
Hope this helps.
Bob
3/4" Hunslet 4-6-0
rrnut-2
Post by rrnut-2 » Thu May 22, 2014 12:16 pm
I also meant to add that you can get these anywhere. Turck, Balluif, Banner, these are some of the manufacturers.
Ebay is not always the cheapest place, also Automation Direct.
Just watch the sensing range and NPN/PNP, two different wiring schemes.
Jim B
hammermill
Post by hammermill » Thu May 22, 2014 1:54 pm
These can also work well for for travel safety / stops
Post by SteveHGraham » Thu May 22, 2014 2:33 pm
Thanks for all the help. I know other people will be Googling this eventually, and this thread will probably be the only place where they find a quick answer.
